Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: RR 03-09-05 .. Multiple Browse ..
  1. #21
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    Guino:
    I would like to request a feature if possible. Would it be possible to have multiple screens (1 front, 2 rear) and have the video/dvd screens output to the reat screens with the controls on the main screen. So passengers could watch movies and you could use GPS for example.
    Rickster
  2. #22
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I do not have multiple monitors to test this stuff with, even so, there are a lot of problems that arise by using multiple monitors -- most new video cards only allow video output on one screen, and having the GPS running while a DVD plays would require lots of processor. It's likely you'd need a special video card OR multiple VGA+touchscreen devices to control everything.
    Ride Runner RR's Myspace
  3. #23
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by manung
    hi guino,
    I do not succeed to make to work the browse.rrl.
    I have executed the instructions, but without result.
    In practical I create the rows browse.rrl, and I insert it in the described distance the rrconfig but when I try with audio browser, it does not appear null in the folder browse.rrl.
    I have tried to hold pressed the button "browse", but it does not happen null.
    How I can make?
    where mistake?
    In attached the file browse.rrl and file rrconfig.
    What I need is to know: where did you place your BROWSE.RRL file and what you have in your RR.INI file.
  4. #24
    Oct 2004
    The file browse.rrl are found in c:\programmi\emule\incoming\mp3 \ and in rr.ini, in section MUSIC PATH, I have the same one (c:\programmi\emule\incoming\mp3 \). I hope to have understood of what you have need.
    For greater clarity I enclose the two screenshot.
    Thanks for the patience
    Quote Originally Posted by guino
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Your screenshot was mostly helpfull.. The problem is between the keyboard and the chair... hehe j/k .. your file name is the issue: BROWSE.RRL.TXT (The filename should be BROWSE.RRL -- NO .TXT) -- If you think your file name is correct (cause it looks like it), you should UNCheck the "Hide Known file extensions" option under the Advanced folder settings. Blame windows if you want...
  6. #26
    Oct 2004
    THANKS GUINO
    NOW WORKS VERY WELL
