Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: RR 03-10-05 - Few things..
  1. #21
    Variable Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    hey guino I Have Lazy TAG off, and i get the directory path for one song, like the example above with the tupac song. you mentioned this shouldn;t happen with lazy tag off, but it does. any ideas?
    thanks
  2. #22
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    have you tried the new version ?? I've fixed a few things...
    Ride Runner RR's Myspace
  3. #23
    Dec 2004
    yup just tried it with the new version... nothing changed. still see the directory path. the song, has it tags fine, (not blank)
  4. #24
    Dec 2004
    Never mind, I just "reloaded" the playlist and all is fine, I haden't reloaded it since installing the latest version
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Interesting.. does it only happen with that specific song ?? If so, chances are that the ID3 tag is damaged or RR can't read it (unsupported maybe).. Now if it happens with a bunch of good songs (not edited by the same tag application), then there might besomething to look at..
    EDIT: good that you got it to work
  6. #26
    Mar 2005
    How about just displaying the filename only in the lazytag option with no path. This way if your files are all named well then you still know what the song is. In my case I have a long path which doesn't fit in the window.
    Also anyway to set an option to change the touch wheel scroll speed?
    I know these are low priority - just airing my suggestions in case they're helpful. Feel free to tell me to shut up!
    Finally all Tag bugs reported in this thread appear to be fixed with the latest version in my case.
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by tji100
    I have to check weather this is possible maybe by just taking path off... the deal is the parsing the path names is just going to slow down the scroll (which is the main reason of existing that option) -- I have to try and see...
    The Touchwheel has no scroll speed set.. it has a limiting speed in case you try to scroll too fast (but you hardly ever reach it). The speed is according to the speed you roll the mouse/finger over the screen.
  1. RR 2-19-05 .. little things..
    By guino in forum Road Runner
    Last Post: 02-20-2005, 12:55 AM
  2. Two things with RR 2-19-05
    By Passe in forum RR Bug Tracker
    Last Post: 02-19-2005, 02:02 PM
  3. Replies: 10
    Last Post: 12-25-2003, 03:12 PM
