Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Night skin AND Gamma
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by kuo
    hey Ol33l, i tried searching around but could not find if you had implemented the night/day skin auto switching for roadrunner using gammacontrol. did i miss it or are you still working on it?
    I'm looking for some XML code so that I can get this whole thing implemented. When I get some code to rear/write/modify XML, then it'll be a matter of days before I get something like this done
  2. #12
    XML bad. Like fire.
    But seriously. Unless it makes something a lot easier (e.g. web services interop)it's a bad choice. All the currently available XML readers are very inefficient. They use a ridiculous amount of memory and cpu. Some of the better (but not freely available) XML readers can chop tens of seconds of app startup (depending on the complexity of the XML). Even for simple XML, the current unmanaged MS XML reading dlls are bloated and slow to page into memory. The managed ones are better but are often the majority of memory churn in managed apps.
  3. #13
    Jul 2004
    Berkeley, CA
    I like XML because it is very organized. So no more confusing INI files with each setting in 20 different places.
    Quote Originally Posted by Arathranar
    XML bad. Like fire.
    But seriously. Unless it makes something a lot easier (e.g. web services interop)it's a bad choice. All the currently available XML readers are very inefficient. They use a ridiculous amount of memory and cpu. Some of the better (but not freely available) XML readers can chop tens of seconds of app startup (depending on the complexity of the XML). Even for simple XML, the current managed MS XML reading dlls are bloated and slow to page into memory. The managed ones are better but are often the majority of memory churn in managed apps.
  4. #14
    That's personal preference. I think it's totally overkill for ini file use and makes things harder for the average person to understand. And if you have an ini file with a setting in 20 different places, you've got a really screwed up design. You can screw an XML schema just as badly - in fact a lot worse since it's more complicated.
  5. #15
    Jul 2004
    Berkeley, CA
    Well, XML is more organized. Like the XML is gonna look like this:
    <GammaControl>
    <NightSkin>
    <RedContrast></RedContrast>
    <RedGamma></RedGamma>
    <RedBrightness></RedBrightness>
    <BlueContrast></BlueContrast>
    <BlueGamma></BlueGamma>
    <BlueBrightness></BlueBrightness>
    <GreenContrast></GreenContrast>
    <GreenGamma></GreenGamma>
    <GreenBrightness></GreenBrightness>
    </NightSkin>
    <DaySkin>
    </DaySkin>
    <NormalSkin>
    </NormalSkin>
    </GammaControl>
  1. Sony Headunit Skin
    By M^ck^y in forum FP Skins
    Last Post: 09-10-2006, 04:33 PM
  2. Gamma AutoSwitch
    By Passe in forum Road Runner
    Last Post: 12-28-2005, 07:47 PM
  3. Skins vs Gamma
    By MC_Stoo in forum Road Runner
    Last Post: 02-25-2005, 01:15 AM
  4. Another Day/Night Gamma Problem
    By carpcnoobie in forum MediaCar
    Last Post: 08-13-2004, 11:52 PM
  5. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 01:16 PM
