Results 1 to 10 of 15
Thread: Night skin AND Gamma
    Constant Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Hello guino, I'm a little confused. I remembr reading that you intended to make road runer so it would be able to have a night skin mode chande as well as a gamma change. This is exactly what i'm looking for, since I would like to have a different skin during night, as well as change th gamma settings. I see in the RR config there is a place to put the directory of you night skin. (WHich I did) NOw I press the night/day button aand I only get the gamma change, not the skin change as well, how exactly can I implement it so both the gamma and the skin change?
    thanks.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There are different commands for skin change and for gamma change, so really the skin needs to have support for it (the BFM skin does for instance). You can most definitely make your current skin do both the gamma change and the skin change at the same button press.. for this, simply edit your menu.skin file and where you see "GAMMA" change it to "GAMMA||DAYNIGHTSKIN" -- You should do that both with your Day and Night Skin. This will make RR switch the gamma and then the skin. The only thing you should watch out for is that if you exit RR in the night skin (with lower gamma), RR will "remember" your last skin (night one) and restore it without the gamma (auto gamma not yet implemented). If this happens you can simply delete your resume.ini file and RR will load the day skin and gamma by default.
    Ride Runner RR's Myspace
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by guino
    Can I use sendmessages to send this command when I get a request to change gamma?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 0l33l
    Definitely.. the above is not really a command but a sequence of commands.. you can do that from the SDK too.. just send in all commands you want to execute separated by || (double pipe).. RR will execute them in the order they're written (left to right)...
    Jul 2004
    Berkeley, CA
    Oh, so I can just send NIGHTSKIN when Gammacontrol determines its night? Tight
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's actually "DAYNIGHTSKIN" to switch between day/night skins. I intend to make separate commands later: "DAYSKIN" and "NIGHTSKIN" as well as "DAYGAMMA" and "NIGHTGAMMA" to elimitate the possibility of toggling things at the wrong time.
    Jul 2004
    Berkeley, CA
    Sounds good. I'll just need the DAYSKIN and NIGHTSKIN
    Dec 2004
    0l33l Are you gonna modify your gammacontrol program, so it also changes the RR skin automatically to the night skin, and then back to the day skin, (like it does already for Map Monkey?) if so I'm very interested, let me know
    thanks
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by cdevelasco
    thanks
    Exactly
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    hey Ol33l, i tried searching around but could not find if you had implemented the night/day skin auto switching for roadrunner using gammacontrol. did i miss it or are you still working on it?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  1. Sony Headunit Skin
    By M^ck^y in forum FP Skins
    Last Post: 09-10-2006, 05:33 PM
  2. Gamma AutoSwitch
    By Passe in forum Road Runner
    Last Post: 12-28-2005, 08:47 PM
  3. Skins vs Gamma
    By MC_Stoo in forum Road Runner
    Last Post: 02-25-2005, 02:15 AM
  4. Another Day/Night Gamma Problem
    By carpcnoobie in forum MediaCar
    Last Post: 08-14-2004, 12:52 AM
  5. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 02:16 PM
