sounds like winamp is not starting for some reason.. the most likely reason is that the winamppath setting is wrong... re-run rrconfig and re-select that path, then you should be able to use it.. also you may want to turn off that "hide winamp" option just to verify winamp is running when RR is trying to play music.. if winamp doesn't start RR won't be able to play any music or use TV functions.. You might also want to check winamp's volume.
This is most definitely nothing with mplayerc, nor related to video.. if you try the above and it doesn't work, please add this line to your RR.INI :
debugmode=true
Then re-run RR, try to use music, then post your RR.INI and debug.txt files as attachments.
LinkBack URL
About LinkBacks
