Originally Posted by cdevelasco
Toady while driving I got that bug of the file in the playlist showing the directory path of the file. It shows fine in the title bar above, but I got the directoy path on the play list. this hadn't happened in a while withh this version, but it happened today. Also, the mouse doesn't auto hide when I return from hibernation. I know its supposed to hide when you shange screen within RR, but even with this it still doesn't hide the mouse. the only way I can get it to hide the mouse is if I go into Map monkey (which has the hide mouse feature) and then MM hides the mouse for me, I then exit MM, and the mouse stays hidden.
