Results 1 to 7 of 7
Thread: Visu and Girder help...
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Hey so I'm having issues with girder and the "VISU" command.
    I assign "VISU" in girder to a button on my remote.
    I hit the button-visualization turns on fine.
    I hit the button again to close my vis window-it changes my songa and my visualization.
    It seems to be locked into the winamp window. I can't change my songs or anything without leaving to the main menu and coming back into the audio screen. Even when I come back, I can't close visu.
    Also, I'm trying to make a multigroup macro in girder so that I can turn on vis and then make it go fullscreen (I don't have a touchscreen to simply click the vis window). The command in windamp for full screen vis studio is ALT and ENTER, but I don't know how to tell girder to hit the ENTER key, I tried the RETURN under special keys, but it didn't seem to work...
    THANKS!
    Oh and I might as well ask this here too, I'm trying to use the same buttons for different things on different screens-specifically the "open folder", and "add", etc. on the browser screen, but when I get back to the audio screen, I want them to be back to "next track" and "GPS" and all the stuff that you see on that screen. Is this possible?
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Feb 2005
    The Yay Area (SF)
    Hey guino, is there anyway that the vis window could pop up within rr instead of on top of it? Or maybe, it could pop up and then somehow give priority back to rr commands?
    The main thing messing me up here is the fact that the visu screen locks me out of rr...once enabled and without a touchscreen, I'm simply stuck in winamp visu mode and weird stuff starts when I hit remote buttons
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've improved a bit on this so that RR still is on focus to receive commands when using AVS and Milkdrop... now, AVS is buggy in it's nature, if it's showing in a wrong/awckward position, you just have to open winamp (ALONE) and run the vis, set the position you wish it to start (before RR positions it) and then close it. When RR starts the vis again, that's where it will show up initially.
    Ride Runner RR's Myspace
    Feb 2005
    The Yay Area (SF)
    thanks guino! looking forward to the next update then!
    I'm working on a girder gml right now that should have all the commands in toggled groups so that your remote knows what screen you are on at all times and you can do everything with an eight way dpad. I'll post it when I'm done.
    Constant Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    any updates with that GML file? i'm interested in something like that, since my remote only has 9 buttons. If you have any progress let me know. I can try to help you if you like, just need a little more details
    Feb 2005
    The Yay Area (SF)
    thanks yeah I have not had time gotta take care of some stuff should be good to work on it on wed. hit me on aim if you want to help, I'm kinda stuck/confused on how to organize it. I was thinking something along the lines of this. but I'm not sure how to do the checks for button presses, only how to do checks for what is in foreground:
    Hit me up on aim if you want, I'd appreciate it! contaygious23
    Dec 2004
    all right cool, i'm willing to give it a try....but I don't have aim, i do have msn messenger. I'll PM you with my email address
