Results 1 to 8 of 8
Thread: Quick Qeustion Guino (concerning international characters)
    Variable Bitrate cdevelasco's Avatar
    Dec 2004
    Miami, FL / Caracas, Venezuela
    Hey guino, once again congratulations on an amazing program. I have a question/problem with international characters. All characters with accents, and the "n" with a "tilde" on top show up perfectly in my title bar for the song, HOWEVER they down't show up in the playlist itself, just a perio apears in their place. I'm providing a picture so you can better understand. Is this a bug? or do you have any ideas on how to fix this?
    thanks
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    For this to work you must NOT disable internationalization.. which may screw up with your fonts (if they don't support your charset). If you turn on the internationalization and it does screw up with your LCD fonts (very likey) but you know that it does work with that font I need the following to adjust the software:
    -Your LCD font
    -Your Regional Settings (Control Panel->Reginal Settings, then tell me the Standards and format, location and under the advanced tab I need the non-unicode application setting you use)
    I'll look it up but can't guarantee it will fix everything...
    Ride Runner RR's Myspace
    Dec 2004
    Hye thanks for the help. Well internationalization is OFF right now (in the picture shown). The font I am using is LCD Display Grid,
    Dec 2004
    setting
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Have you tried to take off the scroll from the title to see if it still works ? I don't think it will... the problem is that you MUST have the computer settings correct for your foreign characters for it to work.. Another option you can try is set the Locale in RRConfig to Eastern Europe (manually)..
    Dec 2004
    hmm tried the eastern european, and it didn't whark. It wouldn't display LCD display grid font unless I disabled internationalization. even then same problem, accent show up in the song title above, but not in the plahylist below. I tried to disable scrool, by changing the value in the audi player skinf, from "scrool" to "center", but the words still scrool, and I can see the accents fine there in the title bar. so kinda stuck with this one huh?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've improved a bit on this for next release..
    Dec 2004
    cool. good news! can't wait to try it
