Results 1 to 7 of 7
Thread: Key press simulation help ???
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I there anyway to simulate a "Ctrl+Shift" or "Alt+Shift" key press in the OSK.
    I need this to switch between Greek and English characters just like you would do on a normal keyboard.
    Constant Bitrate elmo's Avatar
    Mar 2005
    Staffordshire, UK
    I only program in VB so alls i can say is if you do too, try the Sendkeys command, look it up, i use it for sending control characters to and from applications
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    yeah i immediately thought the sendkeys command too when i saw the thread title. It's pretty useful.
    Dec 2003
    Greece
    Is this sendkeys command part of RR command set or is it VB stuff. I am no programmer so if it is VB stuff I certainly cannot use it. I am looking for something that is already or will be implemented in RR.
    Thanks anyway
    Mar 2005
    Staffordshire, UK
    I have no experience of RR but if you have a command where you can assign a program to a button then you could make a simple VB application that sent the keys to the system and then closed itself, and assign that program against a button.... hey presto
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    tolisn... I have this in my to-do list.. but you will need a button in the OSK to make it work...
    Ride Runner RR's Myspace
    Dec 2003
    Greece
    Quote Originally Posted by guino
    Thanks Guino
    The button will be no problem for me. I can easily include it in my OSK.
    Thanks Again
  1. image on key press?
    By mutilator in forum Software & Software Development
    Last Post: 01-30-2006, 07:35 PM
  2. NaviVoice v.6 RELEASED!
    By 0l33l in forum PowerVoice
    Last Post: 10-11-2004, 01:34 AM
  3. Head Unit Help (about to press the order key)
    By EvilInside944 in forum General Hardware Discussion
    Last Post: 12-29-2002, 11:48 PM
  4. Simulate key press right before shutdown
    By Jake in forum General Hardware Discussion
    Last Post: 12-05-2002, 05:57 PM
  5. HELP - Boot requires F1 key press
    By mkkbb in forum Software & Software Development
    Last Post: 05-10-2002, 05:53 AM
