yes, pretty much..... to update, simply download the BINARY package ONLY and unzip it over your files. It will not mess with your INIs, settings etc -- But you should always run RRConfig afterwards to make sure your settings are correct.Originally Posted by Rs!
The Source package has config and INI files I leave in there for example only, but they'd be overwriting your current settings and INIs -- so no good if you're NOT developing stuff in/for RR.
To fix your current state: simply run RRConfig and set all your settings as you wish... THEN you should delete the RESUME.INI file to prevent RR from trying to resume music, shuffle&repeat AND more importantly the last skin used -- it will load the skin setup in RRConfig.
That's all,
Guino.
LinkBack URL
About LinkBacks
