Results 1 to 4 of 4
Thread: Sending keypress's to RR ?
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Hi G, what method would I use to send a keypress to RR.. I have grabbed the handle.. but cant seem to get anything to work, this is for a different project. not flash.
    Say I'm after sending say VOL+, now I can add a "85","VOL+" so when I press the U key the volume goes up.. I have looked at commands sendkeys / postmessage and sendmessage.. is it poss you could give me a example
    cheers
    CdR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I assume you're talking about mapping the letter U into raising the volume in RR... just open your KeyTBL.INI file and add the following line:
    85,"VOL+"
    That's it... You can use the keycode tool to come up with combination of keys .. for instance, if you want CTRL+U to raise the volume you'd use 2085 instead of simply 85..
    Let me know if that's not what you wanted..
    Ride Runner RR's Myspace
    Feb 2004
    Manchester
    yep I already sussed that bit out.. :-) so now when I press U when RR is in focus it does increase the sound.. what i'm after is the correct command that I send to RR from another app to do this.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ahh.. you want to simulate the keypresses to send commands to RR... just send in whatever command you want in quotes like: "VOL+"
    You can simply type that stuff with RR in focus to try it... but I definitely recommend the sendmessages interface when possible -- it is cleaner, and simpler.. the VB code is even available with RR's source (SDK example) -- in there you just have to enter VOL+ or VOL- (no quotes)...
  1. My small hardware to RR
    By mauri in forum Road Runner
    Last Post: 11-28-2009, 04:43 PM
  2. RDS Radio in RR.
    By CherokeeChief in forum Road Runner
    Last Post: 01-07-2008, 10:44 AM
  3. Problems playing DVD with RR 03-08-05
    By Passe in forum RR Bug Tracker
    Last Post: 06-24-2006, 12:36 PM
  4. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  5. RR 03-07-05.. Few Improvements..
    Last Post: 03-07-2005, 06:44 PM
