Hey,
nice the next update
I've wanted to test the browser, but the "WEB" button code didn't work?!
Winni
March 19th, 2005:
* Added support for Switching-Merging labels on Skins
* Added Support to simulate button down/up events from Flash
* Added Support for Flash/SDK to seek to song/video position
* Added OSK search support for Playlist and Folder's current list
* Added Web Browsing support (FireFox and I.E.)
* Fixed Minus1 List Update Bug
* Added Error/Freeze Preventions
Basically some new skin features and a few fixes..
Oh yeah, the Web Browser support.. Please download the BrushMetal Skin Update.. You will need to create a button with the "WEB" code wherever you wish to pull up the web browser. It uses the (imcomplete) skins made by RoyN, but it can most definitely be redesigned. You also need to set which browser to use and it's path in RRConfig (I recommend FireFox). You can pull up the OSK by clicking the RR Logo, this allows you to type stuff wherever you have the cursor at the page.
I've started work on MapPoint support due to a generous donation towards that. I will probably not make any major updates until I'm done with that.
Let me know, of any major bugs (I can definitely fix stuff while developing MapPoint support)...
Guino.
Ride Runner RR's Myspace
Hey,
Winni
Just tested here Winni, worked perfectly, I switched the launch code in the menu to WEB
how do I implement the searchlist function? I put the following line in the "audio_Player.skin"
B21.560,130,100,70,"SEARCHLIST",""
but when I click in that area of my skin nothing happens.
Hey Cdevelasco, I've just tested here, working ok.
Did you copy and paste that Line??? there is a . after B21 instead of a ,
wow... nice update guino! i have a question about all these new features being implemented. How can we access all these functions if we dont have the proper skins to actually use them? It seems as though we need some major re-sknning done if anyone is up for the task. I would love to use the Search function i just have no clue how to implement that in the current skin. (as well as integrated we browser)
thanks again and keep up the great work!![]()
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Yeah, I made it
I have downloaded a defect zip file and first I didn't recognized it by extracting. Downloaded it again and now all is working perfect.
Perhaps one advantage of the search function were if you can receive more results or you could search further if the "wrong" mp3 gets selected.
Only one question Guino: Is Searching through all mp3s on hdd is too difficult?
But very good work
Winni
does anyone know how to modify the osk skin so that it does not cover the entire screen? i'm trying to make it just slightly shorter and start it at x=0, y = 100. aslo, the osk does not work with iguidance/routis. the osk works fine with notepad and the windows calculator. with ie explorer or explorer only the last character entered in the osk gets passed. is it possible that because iguidance uses separate windows when you go to the address input menu, the osk does not pass values to that window? i assumed that the osk would work with the last active window.
If you don't have the BrushMetal Skin update, that's exactly what happens.. It can't find the wbrowser.skin so it doesn't open it.Originally Posted by Winni
Search for all files is planned. You can continue searching the playlist by pressing searchlist again and entering what to search.. I may prevent it from clearing the last search text.. but the search starts at the CURRENT selected item and ends at the end of the list.. so you can keep on searching..Originally Posted by Winni
