Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 52
Thread: I-BUS sterring buttons now working for RR
  1. #41
    May 2005
    Muscat
    Quote Originally Posted by drex
    any update on solving the problem with hibernating and the Ibus serial connector on USB dongle?
    thanks
    i never hooked it again.
  2. #42
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Does anything else need to be done other than using the above files? No modifications to the KeyTBL.ini or anything? I had the ibus working with Frodo, and now I'm using RR with the exact files above (changed the com port to the one I'm using), and button presses make the RR screen flash a little, but no action. I'm sure I have something wrong somewhere, but after a few days of looking at it I've not figured it out.
  3. #43
    Jul 2005
    NJ
    hey guys are you using blitzsafe adaptors or some kinda aux adaptor to your cd changers..if so doesnt your aux adaptors plug into the ibus? if so which cord do you plug yours into...i have an aux adaptor that plugs into the sound but also plugs into the i bus cord...not sure if blitzsafe does but mine does. can anyone help me...im still tryin to figure out which i bus cord i plug into..i have 2 different sets of cords...cd changer ones...and then some other set which has a thicker connecter but also has a i bus cord.
  4. #44
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    it's it's actually a solit state device made by a guy in Germany that hooks directly into the iBus. Most people hook it into the CD changer port... because it's no longer needed and already in the trunk, but you can also hook it into the center console port.
    The ibus cord is actually a small flat three wire plug.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
  5. #45
    Jul 2005
    NJ
    hey thanks for the post....i already have the piece..just tryin to figure out which one to plug it in...so for example my cd changer cord has the audio and i bus plug into my aux adaptor for some reason...can i just plug the i bus controller into the other i bus cord in the back...because i am positive i have two...one goes with the cd changer cord..and the other is the pre wired phone control cord..please let me know
    thanks
    Jason
  6. #46
    Mar 2005
    Seattle Area
    if that's an ibus port... then yes. my car didn't have a phone in it, so I don't know if that's what it is (it would make sense there would be one back there for the brain though. You can try it, but I'd check the Yahoo group "Hacktheibus" or some E46 boards first just in case.
    Matt Atkins
    '98 540i-6 blk/blk
  7. #47
    Feb 2005
    Atlanta, GA USA
    Quote Originally Posted by Hark
    bump - CDR, any ideas?
  8. #48
    Mar 2006
    v 2.0 Source
    CDR - Any chance you could post the source for the hibernation support? My com ports tend to be 10+ and that requires a slight tweak to the original ibuscomm code..
  9. #49
    Mar 2006
    Also - still no luck resuming from hibernation with your v2.0 - it stops responding. Disabling the USB/Serial in system:hardware and enabling it makes XP search for drivers - I just want the system to resume out of hibernation! Looks like I may have to tap in elsewhere and leave the CD player intact so that I can avoid having to hit the CD/Tape button when I start my car.
    Any help with this?
  10. #50
    Mar 2006
    DO NOT PLUG YOUR PHONE JACK INTO THE IBUS CARD. It will likely fry your card at worst. AT best, it will not work. The phone jack, while the same connector as the ibus is NOT an ibus signal carrier and will NOT work.
  1. How-To: Relocating Screen Buttons
    By Altimat in forum Fabrication
    Last Post: 11-07-2007, 03:48 PM
  2. Road Runner on Xp nlited no buttons working
    By mick0uziel in forum Road Runner
    Last Post: 03-14-2005, 12:54 PM
  3. Replies: 7
    Last Post: 02-05-2005, 06:41 AM
  4. Where To Buy Buttons, Switches, Lights?
    By eCarô in forum General Hardware Discussion
    Last Post: 02-22-2004, 02:25 PM
