Sorry Beaver, I will fix the project paths and re-upload the source. v0.3 should be done today with a few new features and bug fixes.Originally Posted by BeaverWise
Arthranar - try pressing the CTRL or SHIFT keys while arrowing around. it already has that functionality.
VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
VERSION 0.3 RELEASED
NEW FEATURES IN v0.3
* Ability to duplicate objects
* Ability to create new screens by copying existing screens
* Change object position by typing coordinates in the status bar
* Replaced the standard VB icon with a little boat
BUG FIXES
* 100% CPU usage when opening a folder with no .skin files, also when deleting the last screen in a project
* Labeled height and width correctly on the status bar
FUTURE FEATURES
* Multiple object selection for moving, resizing en masse
* Copy / paste objects between screens
If you can think of any other (reasonable) feature, let me know.
Guino,
I don't know if all of these are valid commands in RR, but they are used on some skins I downloaded and they are not in the "skincommands.txt" file
"GAMMA" - (works) Switches between Day and Night gamma settings
"PRESET;X" - (works) Loads audio/eq preset named "X.pst"
"TV" - (works) Loads TV skin. Same as "LOAD:TV.SKIN;TV"
"CD" - (does nothing) This one is on the brushed metal skin (updated version)
"SEARCH" - (does nothing) Also on brushedmetalhonda (updated version)
I don't think the last two do anything.. the first three need to be documented -- I probably forgot.. thanks for pointing out... the "CD" feature is unecessary and the searches are supposed to be "SEARCHLIST" and "SEARCHFILES".. the last one is still not implemented.
Ride Runner RR's Myspace
guino, how do you plan on implementing the "searchfiles" feature? would it be like frodoplayer where you bring up an OSK type a string in the box and then only display the files that match in the playlist screen? i know your busy with mappoint integration, but i also wanted to know if this feature is one of the top priorities on your listthanks again bud
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Ta - didn't know that was an option. I tend to do most of my playing around on a slate Tablet PC which means combined keyboard + 'mouse' use is difficult.Originally Posted by BeaverWise
Searchfiles WILL be like this: go on the browser, hit searchfiles, osk comes up, then enter what to search, it would start searching and adding them to the browse list... you'd then be able to add the matching directories/files onto the playlist as usual.. you can then do other searches until you have all you want, or use the "go home" feature to browse normally again..
sweet... sounds good , cant wait!![]()
is this feature just around the corner?
Excellent program it makes it all so easy. The only thing to make it perfect would be ability to drag and drop the boxes.![]()
