Did you associate the Girder events with the commands in RR's GML file ? -- It does NOT have anything associated by default.. You don't even need the remote to test the commands -- just open RR, and Girder, right click on the command "PLAY" for instance and hit "Test Command" RR should respond to it even if the remote settings are not setup right. If it doesn't respond, then there's something wrong in the Girder GML file or RR.
LinkBack URL
About LinkBacks
