Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: hibernation problem
  1. #11
    Nov 2004
    Frankfurt am Main / Germany
    No one any idea????
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll test your skin today, but it's odd that a skin would have such effect.. I'll let you know..
    Ride Runner RR's Myspace
  3. #13
    Nov 2004
    Tested my skin on my home pc and had no problem... maybe there is a problem between my skin and one of my carputer hardware parts! maybe something a little bit dirty in the .skin files???
    btw.. updated graphics drivers and unplugged my dlink usb radio...
    hardware:
    don't remind mainboard brand
    800mhz duron
    128mb 266mhz ddr-ram (infineon)
    20gb hdd
    geforce4 mx440(same as in my home pc with same driver)
    Creative Soundblaster 512PCI
    dvd-rom
    usb-touchscreen
    HI-202E (GPS-Mouse)
    maybe that helps...
  4. #14
    Low Bitrate chilli_pepper's Avatar
    Aug 2004
    Midlands, UK
    I have this problem 2 but only when MapMonkey is running and embedded. If I close map monkey before hibernating then starts up and carries on with Road Runner fine..
    might be something to do with map monkey and the usb GPS (BU303) I am using?
    Just a thought? Would like to get his solved and improves boot quite a bit
    Chilli_P
    Epia 800 > 3.5" 30GB HD > Teac Slim CD > BU-303 GPS > Safecom Bluetooth > WiFi > Xenarc 700TSV > Opus 150
    Current Status:Installed - tweaking
    Want Widcomm 4?
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It is a known fact that using COM/Serial ports can sometimes cause issues with Hibernation -- this is why I close any Serial ports opened before hibernating then re-open them when resuming... I'm assuming you have a USB-Serial driver installed, that is something that creates a virtual COM port.. this could very well be the issue...
  6. #16
    Nov 2004
    Yes, using the virtual com-port.... but never had problems befor with it I even ever used the power switch to shut of my carputer which is set to hibernate....
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    so you're saying that if MM is open and RR is NOT, you have no issues whatsoever ?
  8. #18
    Nov 2004
    Yes ...
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    is this still happening only with your skin too ? sorry hard to keep track of all user's questions .. can you try turning off the TCP/IP interface of MM (in it's settings.ini) and test to see if the problem happens like that ? I have a guess of where the problem might be but not sure of why..
  10. #20
    Aug 2004
    Midlands, UK
    I will try these suggestions also and report back soon
    Chilli_P
    Want Widcomm 4?
  1. I'v had a thought! - Make Hibernation Better?
    By mick-uk in forum WinNT Based
    Last Post: 05-19-2005, 08:39 AM
  2. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 05:41 PM
  3. Problem with interrupted resume from hibernation with XP
    By Mastiff in forum General MP3Car Discussion
    Last Post: 01-25-2005, 04:46 PM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 11:55 AM
  5. windowsMe hibernation
    By moahdib in forum Software & Software Development
    Last Post: 08-03-2000, 11:07 PM
