Results 1 to 10 of 15
Thread: Phoco - not for now...
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Unhappy Phoco - not for now...
    Hi Guys,
    I got ahold of Hematec's code and was having a go with it, but at this moment I have decided to pretty much abandon my phoco integration project to RR...
    My reasons are basically:
    - I think guino can do a much better job, and he has access to PhoCo's SDK (if you dont have it I can get you hooked up but I think you already have it)
    - I think guino would end up re-doing the whole thing if I even did integreate it so I dont think it would warrant all the effort...
    - I'm really pressed for time these days with work+school...
    - I'm more willing to put up a substantial donation to Guino for this... Maybe others can chip in just for the phoco to gain more priority (like he did with MapPoint)
    - Hematec's code seems to be a re-work of the phoco sdk, which I would have adapted more straightforwardly.... It seems that hematec has more code than is really necessary with the SDK, which I would have used. I'm not sure if hematec even used the full phoco sdk...
    - I cant for the life of me get to understand the inner workings of the skin system, it is jsut I have been away from VB for so long it just doesnt make much sense...
    - So basically, Guino, I'm not going to be able to work on this for some time, do you think you will get down to this?
    - If we get a donation pool, can you raise priority on this?
    - Is anyone else interested in working on this?
    I can hook anyone up with the SDK by contacting Zorro. It is basically a fully functioning version of Phoco, but it works from within VB, with a class. No need to use XML and other stuff directly I think, the class does everything with just procedures like Phoco.Dial("5551212") or Phoco.SendSMS, etc, etc...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have the Phoco SDK as well as Hematec's code.. he has made a few nice things onto it, but there are some things that are better off changed.. the skin portion of it has hardly anything at all at this time, BUT it's fairly easy to add.. I will not work on this until I'm done with MapPoint, but I believe that'd be the very next thing to work on..
    The Biggest Thing I'd like to see is to to get rid of that damn dependency to MSXML2.6 .. I can't stand OCX modules, they're big, they give users a lot of problems, and what sucks the most, they have to be shipped with the software... If there was any way, somebydy would simply parse the XML messages from Phoco directly with VB code that'd be great.. if not, then I guess we're stuck with that OCX.
    When I do get to it, I intend to review both Hematec's code and Phoco's class to see what I should do.. I will most definitely need to work with someone to test this stuff..
    Ride Runner RR's Myspace
    São Paulo, Brazil
    Hi Guino,
    I can definitely help you test it out as PhoneControl is working in my car with my phone... (On my computer however, due to a bluetooth problem with the builtin bt of my computer, I couldnt get it to worked, which was one more reason to chicken-out of developing the phoco extension)...
    Come on guino, no numbers to help define a "substantial" donation?
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    If also my help can be useful, I am available for the Testing
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by guino
    Sure, you can parse XML messages with VB not using XML-DOM, but honestly, I wouldn't do that. The 2 main reasons are:
    1. It could get very complex
    2. It sure will be an performance issue
    I've checked the SDK's compatibility on MSXML 3 (right know MSXML 4 is referenced) and it's working well with the older version (not sure about 2.6).
    This version you don't have to install. It's part of the IE so it's supposed to be installed everywhere you have IE 5, 5.5 or 6 (what should be the case for 98% of all computers). Bottom line is: You don't have to ship it.
    The other thing you need is the MSWINSCK.OCX, which is more or less a wrapper to the WinInet lib. So, it wouldn't make much sense to make a own wrapper.
    If you don't want to spend too much time on the PhoCo plugin, do this:
    - Make a VB Form
    - Run PhoCo in the background (see: http://zhorvat.dyndns.org/PCForums/S...spx?ForumID=46)
    - Call the Phoco.Show(...) method and pass the handle of your Form to it
    PhoCo then will set itself as a child of this Form. Then you only have to monitor the IncomingCall / InCall messages to know when to mute the player.
    Skinning and stuff can be done in PhoCo's VisualDesigner
    Skinning to go... VisualDesigner2!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Thanks for the heads up.. I'll definitely keep the MSXML3 reference then.. regarding Winsock, I already have a wrapper for it.. ends up much smaller and without any requirements while providing the same exact functions of the OCX. The benefit from having Phoco integrated to the skins comes in when trying to control it from multiple screens -- that is, without having to switch screens...
    Thanks again..
    Guino.
    This may be a moot point now - Zorro has decided to take the entire PhoneControl project down. Not quite sure why yet.
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    it would be great to integrate phoco into RR, one thing i have a problem with is that phoco dont run on nlited versions of XP Pro, well my nlite settings dont work in my case, maybe someone knows the reason why, i gave up after 22 versions of nlite tweaking. but just to make a point, nlite versions are good since they boot faster, i have considerable improvement in my boot times now from like 1 minute give and take from win 2000 pro to about 15 to 20 seconds on nlite xp pro sp 2.
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    What are your hibernate resume times? Is it really worth it? I have a full OS install which resumes from hibernate in ~20 seconds - 15 seconds of which are in the crappy BIOS screens. With a good BIOS, that'd be 4 seconds tops giving me a resume time of under 10 seconds.
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    aw man i just noticed that too, what happened to phoco and will we have an alternative? I sorta built a carpc for music and bt integration via roadrunner grrr. I already had nav video on my screen etc etc.
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  1. Got SE T608 (Sprint) to work w/ PhoCo
    By Mbai2 in forum PhoneControl
    Last Post: 03-10-2005, 07:40 AM
  2. PhoCo 1.4 RC1
    By execute in forum Centrafuse
    Last Post: 03-03-2005, 04:43 AM
  3. What Phone do you use with PhoCo?
    By ShawJohn in forum PhoneControl
    Last Post: 02-19-2005, 07:32 AM
  4. Problems when connecting with PhoCo
    By zorro in forum PhoneControl
    Last Post: 01-22-2005, 09:31 AM
  5. GRPS, PhoCo, Uploading = GPS Tracking
    By OriginalNick2 in forum PhoneControl
    Last Post: 01-15-2005, 07:13 AM
