Results 1 to 9 of 9
Thread: Oh god, you're using SAPI 4!?
    No wonder I didn't recognize the dll. That has to be fixed. . SAPI 4 is the worst API ever. And SAPI 5 (totally rewritten API) is in the OS from XP onwards.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Here's the deal: I don't have SAPI 5 installed, and really I installed the SAPI 4.0 because of a very simple reason: I am not about to install 200Mb worth of stuff (the SDK for 5.1) on my development machine just to have the computer telling me things I could deal without in first place. I chose SAPI 4 because it has very small runtime distro files and works as far back as Win98..
    Now, if you can find me an easy way to replace the SAPI for text-to-speech object for the newer one (this means without installing 200Mb of files in my machine) AND most importantly, find a reasonable size runtime distro for the SAPI 5 that works as far back as Win98SE... Then, I would be more than glad to replace it..
    Ride Runner RR's Myspace
    All very good points. I guess it ain't broke so doesn't need fixing . Still, yuck . I'll add SAPI 5 support for WinXP+ with no required re-dist to my list of things to do. I'll stick the SAPI 5 sdk on my box and see if there's a nice useful redist for just the speech + voice piece. I'm sure there should be.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hey, I just found a way to use the built in SAPI 5 from XP in VB without installing the SDK (that was different) .. anyway, I'll make an option to set which version to use since I doubt SAPI 5 supports older windows (and I know there's a lot of users out there with Win98).
    I thought you should be able to from VB. I just coded it up too . Do you want the code? It's pretty simple:
    New form - frmSpeech5
    Code:
    Option Explicit
    'Declare the SpVoice object.
    Public Voice As SpVoice
    Private Sub Form_Load()
    Set Voice = New SpVoice
    End Sub
    Then instead of using frmSpeech in your speak method, the code would be:
    Load frmSpeech5
    frmSpeech5.Voice.Speak Words, SVSFlagsAsync
    SAPI 5.x supports back to Win98 - I set the redist file downloading (it's 130mb) but it's painfully slow. There should be a TTS-only redist in there that you can make available for Win98 users. Leaving the SAPI4 stuff in as an option is nice since there are still a lot of tts voices available for it (I was surprised!).
    Ah, but of course, the redist is only in msm format which aren't installable standlone . Someone could easily create an msi that installs the core SAPI 5 dlls + the tts engines downlevel. I'll have to see whether the msi installer stuff built into Visual Studio lets that be done easily. We'd be looking at about 6.5Mb though - so it's large compared to sapi 4 since it contains 3 voices.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well here's what I did for now.. removed frmSpeech altogether... created a VoiceObject that is set at start to either a DirectSS or a SpVoice object.. they both support the speak method.. The users will be able to use SAPI5 by adding this line to their RR.INI:
    sapi5=true
    Otherwise it will default to SAPI4... I have tested it and it seems to be working well on both of my machines (one has no SAPI 5 installed, the other has both).
    Can you make it default to Sapi 5? And fall back to Sapi 4 if not available. That minimizes the user setup requirements. The override could then be to force SAPI 4 usage for someone who had installed SAPI 4 and preferred its choice of voices.
    I assume you are still using the async flag for the SAPI 5 call?
  1. How to find SAPI 6.1
    By 0l33l in forum PV FAQs
    Last Post: 08-03-2006, 06:52 PM
  2. sapi 6.1 from Office 2k3 CD
    By Custommx3 in forum PowerVoice
    Last Post: 08-28-2005, 12:41 AM
  3. Can't Get SAPI to work after Resume
    By Jstarko0329 in forum PowerVoice
    Last Post: 10-18-2004, 09:24 PM
  4. SAPI Engine
    By BeamRider in forum PowerVoice
    Last Post: 10-14-2004, 04:47 AM
  5. Delorme StreetAtlas 2003 SAPI 4 upgrade
    By gfoulks in forum GPS
    Last Post: 05-08-2003, 01:03 PM
