Results 11 to 20 of 30
Thread: Status..
  1. #11
    was Boston -> now Canada!
    Quote Originally Posted by dougmorgan99
    I just want this to die like MediaCar!
    I think we know what you mean (insert "don't" in between just want!)
  2. #12
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    hey guino going to check out all the new stuff right now
    yes peeps please do donate money. Every little bit helps I'm sure
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Thanks for the support guys...
    The Mappoint is almost finished along with many of the features above listed.. Still working on it... There are two features I do not believe I'll be able to complete with mappoint:
    1-Show Pos On Road -- As Far as I can tell, Mappoint does not give enough information to be able to locate the closest road path from a specific location, so I don't believe mediacar's pos on road works (although the option is there).
    2-Spoken voice alerts for route guidance -- I have worked on this for 2 days without any success.. the problem is that Mappoint's directions don't include the turn point locations, but instead, a "segment location" that basically is a somewhat random location in the middle of the route segment used for zooming (when not using GPS). I went as far as trying to triangulate the turnpoints from those middle points, but as I said, they are somewhat random locations centralized against the screen instead of the segment route. I was really looking forward for this feature, but it just isn't reliable.. the most I could make is to count the travelled distance and compare with the direction distances -- but any off route driving would basically screw up the whole thing..
    I did manage to add Nearby locations search, Autozoom and single point route calculation (starting from GPS location) for ease of use... but if I had the turnpoint locations I'd definitely could do a lot more..
    Ride Runner RR's Myspace
  4. #14
    Low Bitrate dougmorgan99's Avatar
    Jul 2004
    Tulsa, OK
    Oops good one chuckster! Yup I DONT want this to die like MediaCar! Hope I didn't put some sort of jinx or voodoo hex on the code. Anyway Guino, I think the voice option would of been cool, but I knew Mappoint is not setup that way. It is a professional mapping software not a point to point navigation program. I've hear people trying to get voice proms working for a while in Mappoint with no success, I figured if anyone could do it at all, it would be you. But don't feel bad I think what you have done is awesome! Thanks!
  5. #15
    Constant Bitrate Cobelli's Avatar
    Jun 2004
    Don't give up home yet Guino, there is a product navstar from mobilegpsonline that claims to be able to do voice nav with mappoint http://www.mobilegpsonline.com/pro_navstar.php
  6. #16
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    if they did it i'm sure guino will find a way
  7. #17
    AutoTouch has very nice MapPoint integration with a nice simple interface. It was what I was thinking of using for my car interface before I discovered RR .
    It does everything though the MapPoint SDK. It has good speech announcements of directions shortly before you need them. I don't really understand what position on road is so I can't say if it does it or not. But it may be worth you taking a look to see if it does what you are trying to do.
    Keep up the great work!
  8. #18
    Jul 2004
    Tulsa, OK
    Whoo! Guino, if I get the software for you, can you get it to work with NavStar? 60 day trial for $13 and Full version for $40. Or do you need the source code to be of use? We have hope!
  9. #19
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I think it isnt just a question of the software, it requires an SDK or other way of interfacing, and it would probably require a hefty donation to Guino, because this really isnt a top-priority since very few people have even mentioned that software...
    Plus there are other priorities out there I think, like Phone support
  10. #20
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Cobelli
    I seriouslly doubt this is very accurate, given that most times it isn't the case that people drive off route.. but the only real way I found that could possibly tell me the position of the turn-points is to keep track of travelled distance agains the distances of the directions... if anybody knows of any property/method/object that can tell me the turn points position, please tell me..
  1. FP 1.09 Status Report
    By frodobaggins in forum FrodoPlayer
    Last Post: 01-29-2006, 05:19 PM
  2. Replies: 31
    Last Post: 12-18-2005, 01:29 PM
  3. How to get rid of the bottom status bar
    By Shmeker in forum Map Monkey
    Last Post: 03-04-2005, 01:30 AM
  4. RESUME_frodo missing song name from status bar.....
    By camsgs3 in forum FP Bug Reports
    Last Post: 12-05-2004, 02:27 AM
  5. Status?
    By Laidback in forum General MP3Car Discussion
    Last Post: 07-29-2004, 09:58 AM
