Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Status..
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by dougmorgan99
    Whoo! Guino, if I get the software for you, can you get it to work with NavStar? 60 day trial for $13 and Full version for $40. Or do you need the source code to be of use? We have hope!
    I'm sure you can simply Embbed it in RR.. if it will give you the directions the way you wish is that I'm a little bit skeptical about.. because I had made even route recalculation code in RR thinking that the locations I had in hand were the actual turn points.. by the way, directions from MapPoint can be worse than D3's directions sometimes.. at least here in BFE KY it quite often is worse..
    Ride Runner RR's Myspace
  2. #22
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, nevermind what I said earlier... I figure out how the heck I can pull more precise distance information from Mappoint -- the same function seems to work in two different ways (very stupid if you ask me), but it's like asking how far from A to B ? and how far from B to A and getting two completely different answers..
    This is still not that precise but works fairly well... I re-wrote all the code I deleted before and now it works good.. so when I release a new version (likely tomorrow night), it will have voice prompts for each direction (much like MM).. I just need to add a few GPS skin commands, prepare RRConfig for the changes and add documentation...
  3. #23
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    You are the heat guino!
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
  4. #24
    Jun 2003
    second that!
    I can't wait to test Turn-by-turn directions in mappoint!
  5. #25
    Quote Originally Posted by guino
    It's those damn one way systems!
  6. #26
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by RoyN
    I think it isnt just a question of the software, it requires an SDK or other way of interfacing, and it would probably require a hefty donation to Guino, because this really isnt a top-priority since very few people have even mentioned that software...
    Plus there are other priorities out there I think, like Phone support
    Phone Control is dead!!
    See:
    PhoneControl Is Dead
    Mauri
  7. #27
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    Is that a problem for putting it in RR? Most of us do have it (even if it's version 1.3) on the pc so we can use it.
  8. #28
    Low Bitrate GRod's Avatar
    Aug 2003
    San Diego
    I agree. Please integrate PhoneControl - I use it and RR and it would be great to have them both working together. PhoneControl works fine as it is so it should be an integrate once and forget about it.
    That's my two cents worth
    GRod
    Carputer/AV System ~95% complete
    Parts all acquired - testing underway
    Fabrication and integration underway
    More on my Ride
  9. #29
    Low Bitrate dougmorgan99's Avatar
    Jul 2004
    Tulsa, OK
    You the Man! Looks like I'm gonna have to double my RoadRunner Development Donation! But unlike having to paying for things from Microsoft , I don't mind ! All because of the top rate support, and Guino's abilities. Awesome!
  10. #30
    Raw Wave
    Jun 2004
    On the beach
    If Zorro decides not to bring Phoco back then there is no point integrating it fully, even version 1.3. There is a major support problem with non-developed software as many will have found out about MediaCar.
    There is quite a bit of work involved to integrate Phoco and if it has ceased development, newer phones won't be compatible etc and Zorro seems to know his mobiles backwards! I was about to start looking at Phoco and how it could be integrated into RR, I'll see if this is something Guino is still interested in,
  1. FP 1.09 Status Report
    By frodobaggins in forum FrodoPlayer
    Last Post: 01-29-2006, 04:19 PM
  2. Replies: 31
    Last Post: 12-18-2005, 12:29 PM
  3. How to get rid of the bottom status bar
    By Shmeker in forum Map Monkey
    Last Post: 03-04-2005, 12:30 AM
  4. RESUME_frodo missing song name from status bar.....
    By camsgs3 in forum FP Bug Reports
    Last Post: 12-05-2004, 01:27 AM
  5. Status?
    By Laidback in forum General MP3Car Discussion
    Last Post: 07-29-2004, 08:58 AM
