Results 1 to 7 of 7
Thread: HELP!! RR can't find skin
    Low Bitrate Bullwinkle777's Avatar
    Mar 2005
    Waynesville, Ohio
    I'm wanting to use RR but I keep getting
    "E:\App\Road Runner\Binary\Skins\DEFAULT does not contain a valid skin! Check your settings and try again." I've check everything and I still can't get it to work.
    Am I an idot and put the skin in the wrong place? Or am I just a moron? Because no one else seems to be having this problem.
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    Run RRConfig and make sure the path is set correctly.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    Nov 2004
    Netherlands
    Just remove the dir DEFAULT?
    Or set the skin directory 1 level up (to ../skin instead of ../skin/default
    As far as I know, RR looks in that dir, and directory-names are the skin names.
    Otherwise you can edit/view rr.ini manually
    *can't check it myself now, i'm at work, car is in parking space outside*
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    check to see if you have a resume.ini file in your RR directory.. if its there delete it. Then try again
    CdR
    Mar 2005
    Waynesville, Ohio
    Thanx to everyone with your speedy replys!!!! As soon As I posted the problem I went back and moved the folder and it works now!
    Thanx everyone!!!!!!!!
    Mar 2005
    Waynesville, Ohio
    O.K. now all of my sliders flicker. Why would this happen?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You probably have sliders with the Y definition.. open your .skin files for the screen with sliders and simply comment out (add a '/,' in front of) the lines that start like:
    YXX,....
    This typically happens with older skins only.. it is faster anyway if you don't have that definition in there -- but this might remove the background effect on your sliders (if any is in place).
    Ride Runner RR's Myspace
  1. New Skin - Spaced_Out for FrodoPlayer 1.08
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-17-2004, 10:50 PM
  2. v.3 SKIN
    Last Post: 10-15-2004, 09:29 PM
  3. new skin idea, need help
    By Electrohacker in forum Media Engine
    Last Post: 09-21-2004, 12:56 AM
  4. Brushed Metal skin v.1.9
    By febsperanza in forum MediaCar
    Last Post: 09-01-2004, 05:45 PM
  5. Laguna Skin
    By CdRsKuLL in forum MediaCar
    Last Post: 06-20-2004, 09:27 AM
