Results 1 to 6 of 6
Thread: canīt play video in RR
    Low Bitrate leckan's Avatar
    Jan 2005
    Dalarna,Sweden
    Unhappy canīt play video in RR
    i have a problem i canīt play movies in RR but if i swith to centrafuse i can play all the movies i have installed all codec i think i need. but it happends nothing when i click play
    Http://www.zinknet.se
    Carweb 2.0 NOW FOR DOWNLOADING
    Oct 2002
    Me neither, just installed RR. I've tried disabling the built in player but still nothing happens when the video button's clicked. Media player classic works outside of RR.
    I've even tried setting the default file associations to media player classic but that makes no difference either. The video browser just doesn't appear.
    Mazda 323F
    Lilliput 7in
    Toshiba Tecra, MapMonkey, DVD, EZ Sync, Roadrunner
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    See if media player classic works outside of RR, then check if the correct directory is set in RR that points to it.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you click video and NOTHING HAPPENS (the video player doesn't even appear) then you have some kind of skin issue.
    If you click video, and the video player appears, but nothing is on there, it is very possible that you just don't have the path to your videos setup correctly..
    If you have made sure this is setup correctly, then try changing the "Built in player" option in RRConfig...
    Everytime you try the video player you should go into the video BROWSER and select the files to play -- because the resume information will probably be invalid from before.
    The builtin player works with MCI (Windows API only) -- if it doesn't work it's something on your machine preventing it from working right.. If MPC works outside RR it should work in in RR as long as the path is correct (basically RR only controls it through the skin).
    Ride Runner RR's Myspace
    Oct 2002
    I'm using the brushmetalhonda skin that came with the installer, and on 2 different machines, car pc and laptop, the video browser doesn't appear. Media player classic works outside of RR and the paths are correct.
    Mazda 323F
    Lilliput 7in
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm going to give a try on the installer right now.. it may just be that there's a missing/damaged skin file in the install.. Have you tried a different skin at all ?
  1. RR 03-15-05 .. Flexibility ...
    By guino in forum Road Runner
    Last Post: 03-16-2005, 12:49 AM
  2. video with AC3-sound
    By viliam in forum Road Runner
    Last Post: 03-03-2005, 05:27 PM
  3. Video Bug in Road Runner
    By goosey2099 in forum Road Runner
    Last Post: 02-28-2005, 06:14 PM
  4. VIA onboard video overlay settings
    By Nanozic in forum General Hardware Discussion
    Last Post: 07-23-2004, 12:55 PM
  5. Divx video playback
    By mindtool in forum MediaCar
    Last Post: 12-08-2003, 05:19 PM
