Results 1 to 5 of 5
Thread: girder on RR
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    girder on RR
    hi guino,
    thanks for the girder gml file for RR, i am not well versed with girder and attaching that girder gml on RR really helps me and other users aswell, one question, how can i make a command, that shuts down the pc with one touch of my remote? what i want is when i press the button on my remote, girder will close all of the open RR apps like gps and audio before shutting down, not sure if it should be a multi process steps but i just want to make sure that everything closes before shut down so as to avoid any running programs from freezing or hanging.
    another question is since i dont have a radio (radiator) on my pc, when i accidentally press the radio function, it hangs RR. is there a way for me to turn off the radion function so i dont click it accidentally?
    one last question on the alpine skin, does it only works for 640 resolution? it doesnt cut it for me on a 800x600 resolution since it doesnt fill the whole screen, am i doing it wrong? thanks a bunch, RR rocks!!!
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you leave the radio setting on "D-Link" it should not crash even if you don't have a dlink card... another option is to simply comment out or change the button code on menu.skin from "RADIO" to "" for instance..
    If you copy a button definition in girder and change the command to "shutdown" you should be able to shutdown the pc with a remote button, RR will close anything that it is controlling except embbeded applications from the Launch screen -- but windows should do that for you.. if by any chance it hangs on some application, then it would probably hang if RR tried to close them too...
    The Alpine skin is availale in 800x600 and in 840x480 .. the one on my site is 840x480.. the Alpine skins are being adjusted by the author (More mods) to support the extra features of RR. I do know for a fact the old Mediacar Alpine skins are still available.
    Ride Runner RR's Myspace
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Is this any use... slightly more advanced as it checks to see which app is running first then uses that command set... edited from an old MC one.
    Terran
    Attached Files Attached Files
    Feb 2005
    ca
    thanks guino, so where can i get a hold of the 800x600 skin?
    also thanks ccsnet for the gml file, i will try it and see what it does.
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is More Mod's site (under construction):
    http://www.carpcs.net/moremods/index.htm
    The MediaCar skins are available for download.. I know he's working on the RR skins right now.. he'll probably post them when they're ready..
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 09:13 PM
  2. IRMAN Girder and Roudrunner
    By BMW5CAR in forum Road Runner
    Last Post: 03-21-2005, 01:56 PM
  3. Replies: 7
    Last Post: 03-11-2005, 01:36 PM
  4. Frodoplayer and Girder
    By leenas in forum FrodoPlayer
    Last Post: 05-01-2004, 12:42 AM
  5. FF and RR - Is It Me ?
    By ccsnet in forum MediaCar
    Last Post: 03-07-2004, 04:53 AM
