Results 1 to 5 of 5
Thread: DAYGAMMA||DAYSKIN - Can't Get It Working
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    I think I am missing some thing here. Searched and read the txt files with no luck.
    Below is an extract from my menu.skn file .... I'm trying to make the skin and gamma changed at the same time so I am using the || function. It does not seem to work at all.
    Cheers in advance every one.
    /, (B) Buttons
    /, x y w h Code tooltip
    B01,013,056,388,092,"AUDIO","Audio Player"
    B02,444,056,388,092,"VIDEO","Video player"
    B03,013,147,370,092,"DVD","DVD Player"
    B04,440,147,388,092,"LOAD;EXTERNAL_TMC.skin;Mobile Web;C:\MobileWeb\mobileweb.exe;mweb",""
    B05,013,238,388,092,"RUN;C:\PCAS.exe",""
    B06,444,238,388,092,"GPS","GPS"
    /,B06,444,238,388,092,"LOAD;EXTERNAL_MM.skin;Map Monkey;C:\DestinatorApps\Map Monkey\MapMonkey.exe;Map Monkey",""
    B07,715,341,077,071,"MIXER","Mixer settings"
    B08,305,425,245,065,"EXIT","Exit"
    B09,593,425,245,065,"DAYGAMMA||DAYSKIN","Gamma mode"
    B10,013,425,245,065,"APPEARANCE","Appearance menu"
    B11,568,341,087,071,"VOL+","Volume+"
    B12,205,341,087,071,"VOL-","Volume-"
    B13,044,341,087,071,"MUTE","Mute"
    Terran
    Raw Wave
    Jun 2004
    On the beach
    Edit your exectbl.ini file and create an entry in there, should sort it out, this lets you do two commands at once.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've just tried doing the same thing here in both BFM day and night.. worked perfect with the same exact command. I can only assume either your settings are wrong (general.ini has no night gamma) or simply you're pressing the wrong button or wrong AREA... feel free to send me the skin file along with the images so I can test it (if you want).. just use my email on my personal profile..
    Ride Runner RR's Myspace
    Jan 2003
    Quote Originally Posted by guino
    Gamma defo in there.... all the settings are from the orginal MC skin I did which worked.
    I'll have a crack atthe above suggestion but I send you the skin file any way
    Terran
    Jan 2003
    Doh - found I had not placed the updated version on my lappy ... how ever ( bear in mind I am using the internal gamma function ) the command switches the skins find and day to night sets the gamma BUT night to day only switches the skin and no gamma change.
    No awhere of any one else using the skins this way so is it a bug ?
    Terran
    PS Defo used the latest version this time lol.
  1. Anyone Destinator working in Centrafuse ?
    By superbowl in forum Centrafuse
    Last Post: 02-05-2005, 11:30 AM
  2. TS working... not working... work... not...
    By bulgogi777 in forum General Hardware Discussion
    Last Post: 01-11-2005, 09:25 AM
  3. Via Epia M-900 Video Drivers Not working
    By mattdisaster in forum General Hardware Discussion
    Last Post: 01-06-2005, 10:33 AM
  4. All built and working, just one last problem......
    By Matthew230 in forum Power Supplies
    Last Post: 10-18-2004, 04:02 PM
  5. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 10:52 AM
