Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 111 to 120 of 123
Thread: RR 3-30-05 ... Mappoint ...
  1. #111
    Mar 2005
    Quote Originally Posted by guino
    Did you try Version 4-4 ? this is exactly what I meant by the GPS Fix I added..
    Hi,
    Tested. This time is worser...I do not have info about gps neither in the upper toolbar. Please see the attachment. The VGPS-pos.bmp is taken with additional tool to see if I have lock. Starting Mappoint through GPS button will show the picture NoLock.bmp Trying to see if showgps made something will send me in Atlantic Ocean, as is in Atlantic.bmp
    Thanks in advance,
    Tolum
    Attached Files Attached Files
  2. #112
    Updated source files to match 4-04 source.
    I also made a couple of tweaks to how you shutdown winamp - sending multiple WM_CLOSE messages can cause apps to crash. I believe that's why I'm frequently seeing winamp crashing at RR shutdown with recent builds. I have yet to see it with my changes but I haven't really spent long enough using it to be certain. Regardless, I think those couple of changes are a good idea - just send one WM_CLOSE and then do the wait for it to take effect.
  3. #113
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by tolum
    Hi,
    Thanks in advance,
    Tolum
    Without a GPS lock, the behaviou you see is normal.. please just tell me that:
    1-You have GPS set to NMEA
    2-You have set the GPS port in RR
    3-NO OTHER GPS application is running when RR starts
    If anything, I'd like to see a capture of your GPS data so I can see it.. you can use hyperterminal for that.. run it (while not in RR or any other GPS app), open your com port with 4800, 8, N, 1 and click on Tools->Capture to File.. get like some 20 secs of data and send it to me please..
    Ride Runner RR's Myspace
  4. #114
    Mar 2005
    Unfortunately my Hypeterm form Windows 2000 does not work so well. I made a capture with VGPS (visual gps from www.visualgps.net).
    As I told you, in the previous version from the 2nd of April the data on the upper toolbar regarding GPS was ok. The only problem was that the GPS was not shown on the map.
    I could suppose that it could be something regarding locale settings again.
    Regards,
    Tolum
  5. #115
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I am pretty sure it is, the problem is that before (when you thought it was right), it wasn't right either .. it's not supposed to show more than 2 digits before the comma/decimal point.. in your case it was showing 4.
    I did test the last version (4-4) here with different regional settings (greek) which uses comma as decimal points and it worked fine .. I'll take a look at this again, can you tell me what country setting you have setup on control panel ?
  6. #116
    Is there any way to clip decimal numbers in a label? My MBM 12V value is something like 11.74950 and I only want to display 11.75.
  7. #117
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Please try this for your GPS issue:
    http://rmc.pimpedwheels.com/rr.exe
  8. #118
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Arathranar
    Edit your .skin file, change the tooltip Text to: "0.00 V"
  9. #119
    Mar 2005
    Solved
    It looks that the last executable solved the problem. It is still showing 5 decimals, but I could live with this, for me this is not a problem.
    GPS locked, showing on the map and at the toolbar.
    I am using pure german Win2k OS as is shown in attachment.
    Well done,
    Tolum
  10. #120
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the 5 digits GPS location is on purpose... less than that is just not precise enough for whatever applications you may have for using that number...
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 08:13 PM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. girder on RR
    By mick0uziel in forum Road Runner
    Last Post: 03-29-2005, 07:00 PM
  4. GPS and MapPoint 2004 questions.
    By wampa in forum MediaCar
    Last Post: 07-15-2004, 05:40 PM
  5. Replies: 13
    Last Post: 07-15-2004, 12:07 AM
