ok... let me do a quick check..
EDIT: Sorry, overlooked something in the GPS settings.. re-download the binary package and it should work..
Ok... As soon as I select my GPS path or application, I get the runtime error. I have ensured my paths are correct.Originally Posted by guino
That is to say... When I go to modify the GPS settings. I can specify the paths correctly, so long as I leave GPS mode at 'Menu'. I can save...everything works ok at that point. The moment I select either MapMonkey or External... BOOM
Ride Runner RR's Myspace
That's got her!Originally Posted by guino
Yok & Yoll baby, Yok & Yoll![]()
ok just tested the radio/tv. the reseting part works great. noticed a few weird things.
1. first time in radio using the fx button to save preset works fine. but after, subsequent time in radio, pushing the f/x button will add the content of the music directory to the preset list rendering the preset list unusable.
2. not sure if this is a mistake on my part but if i select do not use id3 tag in rrconfig, the tile of the artist doesn't show up only the title of the songs are display in music player and browser. same effect in video player/browser.
update: **figured out the video problem. had to use external player.***
3. i have a few video that would play in rr but it would play fine in winamp. rr would see the file and allow you to select it but it would just skip to the next file.
good work.
How do we use the Labels SDK?
I can see the skin command but how is it 'sent' to RR?
well.. you'll need to create a label in the skin that starts with ! for example: !MYLABEL
from the SDK, you would send a command like: setlabel;!mylabel;MYTEXT
You should then be able to view that label with the "MYTEXT" text in it.
You can test it using the SDK example included with the source package.. there's a Delphi and a VB6 example there..
Ah ok, haven't dl'ed the Source package, only the Binary - my bad .... sorry.
Works perfectly :-) Just set up connected/disconnected indicators for my GPRS Connection.
sweet nice work!
Hey with the SEND command, what are the embedded applications that you refer to? calculator, etc. or what?
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
the SENDKEY Command will work with any embbeded application currently focused.. if Calc was running for instance and you execute "SENDKEY;1" it would simulate the pressing of the button 1 in the calculator.. this allows for improved emmbeded application support specially when making separate skin files for specific applications.
Now I must get up early to install this on my car pc and reconnect the USB devices (I'm in the middle of the final wiring for my install) so I can test it on my way to work![]()
Keep up the great (and frankly astoundingly quick) work!![]()
