Results 1 to 10 of 11
Thread: how to view mbm value in RR?
    Variable Bitrate slimmegane's Avatar
    Feb 2005
    Italy/Lecce
    Hi,
    How to can I view CPU and Case temperature in RR?
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    1.First you have to run MBM5.
    2.Check that mbm5 supports your motherboard
    3.Then insert these lines in your skin file
    L08,761,098,060,025,255,255,255,16,"ArialG","MbM2" ,"0.0C"
    L09,761,171,060,025,255,255,255,16,"ArialG","MbM1" ,"0.0C"
    4. Change the coords and the font according to yout nneds.
    These lines will give you CPU and case temeprature.
    The road is long but we are getting there.
    Feb 2005
    Italy/Lecce
    Hi,
    thanks for you reply, I've try but I only have 0.0C, there is some setting in MbM or other plugin to set?
    Raw Wave
    Jun 2004
    On the beach
    Check you have updated and selected the correct Mobo in the MBM config.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    make sure MBM is running too -- that's an often mistake. If it is running and you can see your CPU/CASE Temp in MBM, you should be able to view them in RR with the skin changes above mentioned. If not, then your sensor numbers may need to be changed.. there's a MBM sensors tool in my page to show you all the sensors information along with their numbers if you need it.
    Ride Runner RR's Myspace
    Feb 2005
    Italy/Lecce
    I'm sure that MbM is running, I've used this line in menu.skin:
    This is the result of MbM monitor from the guino site:
    Sensor 1: Case / 25
    Sensor 2: CPU Diode / 51
    Sensor 3: CPU Socket / 42
    I've only 0.0C in RR skin!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    sorry this was a bug introduced in the latest version.. download this to fix it:
    http://guino.home.insightbb.com/rr.exe
    Feb 2005
    Italy/Lecce
    Hi Guino,
    Thanks very much, the problem is resolved, thanks!
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Hi,
    I have installed MB5 too. I can now display the CPU and motherboard temperature in a skin. But how can I display other values such as fan speed and voltages?
    Raw Wave
    Jun 2004
    On the beach
    Just use the sensors program on guinos site and substitute the relevant mbm sensor in the skin for your motherboard
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 08:13 PM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. Why are u putting a PC in a Car?
    By 00GMC in forum Newbie
    Last Post: 04-06-2005, 03:10 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 12:47 AM
  5. girder on RR
    By mick0uziel in forum Road Runner
    Last Post: 03-29-2005, 07:00 PM
