MM is not really an application embbeded in RR.. it is NATIVELY INSIDE RR's skin. The only way you could use sendkey with MM is if you disable the TCP/IP interface in MM's settings.. that of course, would disable all the "MM;xxxx" commands .. which means, all you'll ever be able to do with MM is what NM wants you to do through his SDK.
LinkBack URL
About LinkBacks
