Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: RR 04-01-05 ... Finishing touch ...
  1. #11
    Jan 2004
    NYC
    Quote Originally Posted by guino
    Album images are now looked for on the folder of the song and ONE folder above if not found in the current folder.
    On the browsers, you can now use Images of same folder or file names to display... examples of matches are:
    D:\Music\Adema\
    D:\Movies\Kill Bill.avi
    D:\Movies\Kill Bill.avi.jpg
    Can someone clear this up for me, cause im at work and will try it later tonight........but does this new feature give the ability to display the album art as a icon , rather then seeing the yellow icons in list mode
  2. #12
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    I updated RR and brushmetal skin today to the latest version and RR has become very slow. I don't know if it's RR or something with the brushmetal skin. Everytime I switch from one submenu to the other it takes a least 10 seconds to open it. Very annoying and I have tried installing everything again but no luck. Till today I was using the 19-02 version wich worked superb. I'm going to try to some more thing (other skin, another winamp, etc)
    Has someone had this problem before in the past? I remembering reading about this somewhere here but can't find it anymore.
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by vortex
    Hi thanks guino for the album art feature i'm seeing allot of art displayed in my skin it's looking great just one thing can you also include .giff as album art as it seems to work if i rename .gif to .jpg so i guess it's not much work to just add .giff.
    Also cannot wait for slideshow album art if you have time to implement this.
    The file type/pattern is set in RRConfig.. it's in the Music Section butworks for Music and Videos.. the *.jpg can be changed to *.gif if you want..
    Ride Runner RR's Myspace
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Clarre
    I got a problem with MapPoint in my car computer. It run well in my home pc, and I've the same settings in my car. I can run MapPoint stand alone in the car, but when I'm using RR it ends up with a error message. Run-time error
    '-2147024809(80070057)': The parameter is incorrect. Anyone have a solution?
    Try deleting the Mappoint.ptm file, and make sure you've run RRConfig and SAVED. My guess is if you haven't changed your settings for awhile, there may be a setting in the old (wrong) format... The MapPointMap setting used to besaved/loaded as "North America" or "Europe", those are now saved as the number 1 or 2, if you still have the old one you could get what you're saying. Also make sure you have the MAPPOINTERS and the MAPS folder inside RR's folder.
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by camsgs3
    no.. at least not yet... I have played around with loading images as icons (for another project) and it is incredibly slow without some type of caching... I'd rather have someone make a Audio/Video Browser screen without the Album art space and with more space for the playlists, then I can work on something that will display the Album "icons" but Bigger and more of them on each screen, and controlled by pages (when it should be ok speed).
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Partybuster
    Only speed issues I've heard with RR are related with Flash.. check the RR FAQs.. If you have a "sticky" serial port and have the GPS port setup, but in use or set to a wrong com port, that could be the issue.. I've seen some funcky **** with wrong serial port settings before..
  7. #17
    Amsterdam
    hmm, looks like a port problem then. But the weird thing is that for example with cdrskull's flash skin everything works OK and that skin is in flash (using more cpu I guess).
    I will check my gps port and see if I have latest flash plugins installed.
    Thanks for your help guino.
  8. #18
    Amsterdam
    Hmm, I don't know if It was luck or not but it's working ok again. I just went into the RR-configurator and I saw an extra option with this latest version: GPS port
    I changed it from 0 to 3 (serial port being used for GPS) and now all works ok. I did not discover it before because I haven't used mapmonkey during all day. If I had it would have give me a nice error about a wrong serial port, hehe.
    Now, i'm going to put mappoint 2004 on the pc and some extra music. I still have 20GB free
  9. #19
    Low Bitrate Clarre's Avatar
    Feb 2005
    Hedemora/Dalarna/Sweden
    I have no mappoint.ptm when I first look. Change settings for GPS Com Port to 0. Then I've it to start but get no GPS lock of course. Then when I checked I have the mappoint.ptm. Tried to set it back to com port 1 and get the error again. I even tried to remove the mappoint.ptm with no luck at all. When I start mappoint alone I get GPS indication on where I am.
    Via Epia M1000
    512MB RAM
    120MB IBM Hard drive
    Netgear MA111
    Lilliput 8" Touchscreen
    http://www.clarre.com/carcomputer.htm
  10. #20
    Low Bitrate dougmorgan99's Avatar
    Jul 2004
    Tulsa, OK
    You ROCK! As promised I will forward my Software Development Fund (donation) tonight! Everyone show your support and see the donations thread! Guino, you should changed your name to "Neo", you truly are a machine! Thanks for the major update!
    Car: 2002 Dodge Intrepid SE
    Car PC: AMD XP 2500+, 1gig DDR, MSI KM4M mobo, GeForce 5200 128mb, Western Digital 250gig HDD, DVD, 802.11g, Rikaline USB Mouse GPS, WinXP SP1
    Screens: Lilliput 7" VGA Touchscreen and Lilliput 7" RCA LCDs
  1. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 03:19 PM
  2. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  3. What TV tuners ?
    By tolisn in forum Road Runner
    Last Post: 03-31-2005, 02:23 PM
  4. AutoTap ODB-2 cable...
    By coleman in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-28-2004, 11:13 PM
  5. GROUP BUY: Lilliput TM-701VGT LCD
    By krystar in forum Classified Archive
    Last Post: 01-16-2004, 06:31 PM
