Results 1 to 10 of 16
Thread: RR 04-02-05 ... Few improvements..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 04-02-05 ... Few improvements..
    Those are the changes of this version:
    # Fixed HORM support to reload winamp songs
    # Fixed Album Art display on screens with no playlist
    # Improved Flash Commands to prevent unwanted repetitions
    # Updated Mappoint's Brushmetal Skins
    # Improved Scrolling Labels display of empty data
    # Added error preventions to Mappoint
    # Added Support for Custom Indicators
    # Improved Mappoint's Directions
    I've spend most of the day updating the buggy brushmetal skin to use the new features with mappoint.. I still have to add the Favorites list ..
    Thanks for you support...
    Guino.
    Ride Runner RR's Myspace
    I can't keep up!
    Constant Bitrate holistic's Avatar
    Feb 2005
    Denmark
    nice job Gman.... seems like there's almost only some tweaking left to do now
    Food goes in here..... that's right ... mmmmm
    Oct 2004
    hi guino,
    update thanks for the numerous ones that you are supplying.
    Optimal job.
    A question: where I can capture the skin for phoco?
    I have tried in all the forum but without result.
    You can help me?
    Quote Originally Posted by guino
    Guino.
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by manung
    hi guino,
    Optimal job.
    You can help me?
    ... with luck UK_MP3 car will have all my skins uploaded later this week... inc a 1.4 BM skin for PC.
    Terran
    Feb 2005
    Rijssen, The Netherlands
    guino great job! cant beleve how fast RR is growing!
    Keep up the good work!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's a Phoco Skin available at: http://rmc.pimpedwheels.com/Phoco.zip
    It of course, needs the Phoco support in RR to work (not done yet).
    Feb 2005
    Hey, great work! The winamp playlist loading for HORM works now. Almost completely finished I think. The thing now is that it always plays the same song on the playlist, even though the playlist changes (Like the 3rd song will always be played on a playlist no matter what was playing before the last shutoff). RR's resume support is a little confused. Stuff like remembering if repeat and shuffle were on isn't saved either (I don't think so at least)... Is there a reload function that is called when RR first starts up? Because that seems like what needs to be called after hibernation to make everything... perfect.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    When Hibernating, RR saves a resume.ini file (as long as you hibernate using RR's option), that stores your shuffle/repeat, last song used and position playing. When resuming, RR is loading that resume.ini file and if it exists, it will set those options as they were last saved.. of course, this won't happen if you don't use the "Resume" option.. I can only assume the resume.ini file is not being propperly saved when hibernating... this is the last thing done before the hibernate itself.. if your HORM thingy doesnt write any left out cache from memory to disk before shutting off, Id strongly recommend stop using it..
    Feb 2005
    HORM doesn't really have anything to do with shutting down any special way. It was created by microsoft so I assume they've thought about any possible problems with it. It's really simple really, you know how when you boot up after hibernating, it loads the hibernation file? Well, with HORM, that hibernation file never gets reset unless you make a new hibernation save or press f8 during startup.
    I'll do some more testing to figure out whats going on.
  1. Replies: 97
    Last Post: 09-18-2006, 01:56 PM
  2. What TV tuners ?
    By tolisn in forum Road Runner
    Last Post: 03-31-2005, 02:23 PM
  3. RR 03-07-05.. Few Improvements..
    By guino in forum Road Runner
    Last Post: 03-07-2005, 06:44 PM
