Right now, you can add to favorites in the Add Location screen.. middle button across the bottom.. search for a location or use the nearby feature, select the location you want to add, hit "ADD" and type a name for it... you can then use it in the route planning screen's "FAV" button ... you can delete what you want form that menu as well..Originally Posted by Arathranar
You can add the current GPS position into the favorites byt using the nearby function and adding the GPS position into the favorites as usual. Although it is a usefull thing to have direct access to, I didn't have time to find a spot for it.
LinkBack URL
About LinkBacks
. The Show Location menu option was working.
. Thanks.
