Results 1 to 9 of 9
Thread: D-Link FM
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    D-Link FM
    Hi Guino & Others,
    I wanted to clear this: how well supported is the D-link usb radio in Road Runner? Is this equipment good for in-car use or not really? What other dedicated Fm tuners are recommended? USB, not very expensive=best...
    My pixelview card just wont work with radiator, and I want something easy to config, I've run out of patience with that demon...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't recommend the Dlink if you use 2000/XP.. it is problematic the least... I am planning to add Radio with RDS support for the Cinergy Card (which is German), but I highly doubt Brazil's Radio stations support RDS as of right now.. If I were you, I'd look at Radiator's page for a list of supported cards, search for prices and compare features and make a choice. The only card I have is the D-Link.. Some users have been using the Hauppauge USB, I don't know how they're powering it (I think it needs external power).. You can most likely post this same question in the hardware forums.. As far as I know, FP and CF both use Radiator, so who uses radio in those front-ends, has gone through the same issue of finding a compatible card, and could give you some advice. I have an actual Radio in the Car (I use for Radio and AMP).
    Ride Runner RR's Myspace
    Variable Bitrate MC_Stoo's Avatar
    Jun 2004
    Manchester, UK
    Early days but so-far-so-good with D-Link and XP
    DC UK Forum
    São Paulo, Brazil
    After searching and finally being convinced of what I should have been a while back... just ordered a hauppauge wintv-usb-fm... I hope i dont have problems with this choice! :fingers-crosse:
    Constant Bitrate cyberlancer's Avatar
    Feb 2005
    Gallarate (VA) - Italy
    so i'm too late ... even if brasilian radio stations don't support RDS or RDBS (but i'm not sure), i can say that Terratec Cinergy 600 TV works really well either as a Tv and Radio card (after card reset option's been added in RR ). strong drivers and full radiator and winampTV plugin compatibility.
    Cheers.
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Using Hauppauge WinTV-GO-FM (PCI) which is working well with both RR and Radiator/Winamp for both Radio and TV. It was cheap and easy to install. Guino was helpful with the last update and every thing is, in a word "Working".
    Good Luck to you all!
    Oct 2004
    Madrid, Spain
    Is it possible to connect a PCI card to the EpiaM10000?
    I mean, I know there is a slot for this purpose, but there is not enough space if you use the Travla box, isn't it?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    depending on the case you have, you may need a pci shifter or rotational slot or leave the case open..
    Apr 2005
    San Francisco, CA, USA
    i hae the dlink dru 100 adn i have had no problems at all. none
  1. Replies: 2
    Last Post: 04-10-2005, 12:18 AM
  2. Replies: 4
    Last Post: 03-11-2005, 02:15 PM
  3. FM Transmitter vs. FM Modulator
    By Uzi4U in forum Newbie
    Last Post: 02-18-2005, 10:20 PM
  4. FM Modulator Question
    By frenchbluefocus in forum Newbie
    Last Post: 11-24-2004, 12:05 PM
  5. Anyone found a new set of drivers for the D Link USB FM Radio ?
    By SAScooby in forum General Hardware Discussion
    Last Post: 08-20-2004, 03:21 AM
