Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: RR 04-06-05... Almost there..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 04-06-05... Almost there..
    Here are the changes..
    -Added support for Top/Bottom Indicators for Playlist and Folder List
    -Added "STANDBY" skin command (alternate to "HIBERNATE")
    -Added support to pull RR's current screen/skin file from SDK
    -Added skin support to send commands to future plugins
    -Added option to Hide Desktop
    -Added Routis Nag screen Removal (Use "ROUTIS" as window name)
    -Improved Select/+ to stay in screen on press and hold of button
    -Improved External GPS support to work with Mappoint (Serial Port control)
    -Improved Hibernate to detect/resume when using power button (thanks Arathranar)
    -Improved OSK to work with the last window on focus (to work with dialogs of embbeded apps)
    -Fixed GPS "cut" window bug on first load
    -Fixed bug when adding current GPS Position to favorites
    -Fixed Route times on Mappoint
    Tomorrow I hope to work on that Base Skinnable Plugin .. that is, if there aren't too many bugs in this version.
    Thanks for your support,
    Guino.
    NOTE: If you've downloaded this in the very first minutes after I posted this thread, please re-download as the file in the server was not the right one!
    Ride Runner RR's Myspace
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Guino what will the Basi Skinnable Plugin be?
    Any word on adapting Zorran's demo phoco application controller (in VB) for phone integration? We spoke of it before I think... this is just a small VB application that has all the remote control functions, and would just need to be skinned/changed around a bit
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have that code for Phoco.. but the idea is to include a little more than just that (internal phonebook etc). If I don't hear from Hematec soon enough I might just give it a shot...
    The Base skinnable plugin will be a basic application+source with all the necessary functions to make applications using RR's (MC) skin format. This will also include all you need to control/interface with RR and pull up any info from it you might need.
    Mar 2005
    Skin Plugin
    Guino,
    When will the skin plugin be available? I was just going to contact you about how to incorporate the same type of skinning into an application that I am working on. That way I can keep things consistent. Let me know and keep up the fantastic work. You rock.
    Raw Wave
    Jun 2004
    On the beach
    Guino mentioned that the app will be released in the next couple of days ... bugs depending in RR due to the latest release.
    Constant Bitrate Trazer's Avatar
    Jul 2004
    The Netherlands
    Guino,
    Everytime i press one of the cursor keys while on the main screen i get a runtime error. Is this a skinning problem or is it roadrunner? cause this didn't happen with a previous version of roadrunner. I'm using the brushed metal skin with the update on your site.
    There ain't no need to cry. Time's up. It's time to die....
    Constant Bitrate Heckle0's Avatar
    Sep 2003
    Colorado Springs
    Guino rocks.
    Thank you from every RR user out there.
    Another Novice?
    Progress so far <-------*-> 88%
    Kenwood MPV5025 with Aux
    Via MII10000
    512MB Ram
    LG Slim DVD\CDRW
    Xenarc 700TS
    M1ATX
    Pharos GPS
    SYBA USB2.0 4-port Hub
    Bufalo 54Mbs Wirelessb/g PCMCIA card
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    Thank you guino.
    Raw Wave
    Jun 2004
    On the beach
    Have you checked your keytbl.ini??? It may have the wrong keycodes.
    Jul 2004
    The Netherlands
    Quote Originally Posted by UK_MP3Car
    I copied all the files from the new zip file over the existing files. shouldn't be a problem should it? But i'll check.
    Edit: Just checked. keytbl.ini is the same as before. It only happens on the main menu screen. the audio player works fine.
  1. I-BUS sterring buttons now working for RR
    By CdRsKuLL in forum Road Runner
    Last Post: 06-19-2007, 08:13 PM
  2. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  3. some song titles make rr hang
    By bigaaron in forum RR Bug Tracker
    Last Post: 04-16-2005, 07:48 AM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 12:47 AM
  5. girder on RR
    By mick0uziel in forum Road Runner
    Last Post: 03-29-2005, 07:00 PM
