Results 1 to 10 of 14
Thread: 2 Q's, SuperSpinFlash and WinAmp Visuals
    I have noticed that lost of people have asked about the "SuperSpiningFlash" logo in the skins. I have downloaded the DLL from the site, but it doesn't say where to put it! I have tried in the RR directory and System folder but the logo still spins a super sonic speeds... What am I doing wrong?
    Another problem I have is that when I hit the Visualization for the music WinAmp loads up the vis, but it doesn't get put into the display and ends up behind RR. I noticed that WA5 (which I am using) doesn't create a seperate window, is that why RR can't find it? Or should I use WinAmp2?
    Cheers from a confused bunny! LOL
    Raw Wave
    Jun 2004
    On the beach
    Place it in c:\windows\system32 then go to start run and type regsvr32 c:\windows\system32\flash.ocx
    Not sure about the visualisations - I'm sure someone else knows the answer to this.
    Nov 2004
    Frankfurt am Main / Germany
    Have u checked ur settings about the vis title??
    even in winamp5 u can show the vis in a sperate window... its something like dtacht visuals or something like that... worked for me with the right window title ....
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    use winamp 2, i had 5 and lots of issues. 2 is faster anyway
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you use winamp 5, disable the modern skins -- use a classic skin.
    Your visualization is detached because you probably need to make sure your default (selected) visual plugin in winamp is setup in RRConfig.
    Your flash spins too fast because you probably haven't updated your flash version. There's a whole FAQ just on this.
    Ride Runner RR's Myspace
    Quote Originally Posted by guino
    That got it, thanks!
    Sorry I had a quick look in the FAQ section but didn't notice it .
    Cheers, great program, far better then the other one I was using before
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yea Guino,
    I have just got around to setting up the visualization in the car and i comes up ok but as far as clicking/touching the right side of the screen it doesn't work...
    I am using milkdrop currently with it set as default in wimamp and RR config. tried several options and still have probs getting out of it... The only way I can get out of it is to tap twice and after it goes to the smaller window, hit the vis button again...
    Any thing else that you could suggest....Thanks,
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Just make sure that your plugin (MilkDrop) is changing the screen's resolution when in Full Screen -- this is what RR detects to allow the right-edge clicks to disable VIS. If MilkDrop is set to use the same screen resolution you use in RR, this will not work (only the double click will). I suggest lower resolutions for improved speed...
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Ok, I tried this and any thing else that I could think of and still no luck....
    I did notice two things though:
    1. Tried to tap on the screen anywhere, and when i taped twice over where the playlist was it changed to whatever that song was...like the vis was a portal and could just reach right though it...normal??
    2. After I get back to the sm vis window and hit the vis button and go into the audio browser I can see the area that I should have been able to use to close the vis...like 2" of the right side...its white. Then I have to close RR to make everything normal again....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Maximum Bitrate PORTUGAL's Avatar
    Oct 2003
    PORTO
    Same problems here...
    When i run winamp the visuals are fast enough, so i dont think i need to lower the resolution.
    But great front end, RR its my choice!!
    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
