Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: RR 04-08-05 .. BETA Base Plugin ...
  1. #31
    Quote Originally Posted by Arathranar
    I've had issues with the voice prompts stopping / not working if I don't follow the calculated route. Once I set it to calculate when on a freeway and it jumped to a side road and calculated from there and I got no voice prompting at all other than the very first one.
    ...even after I was on the route it had calculated (i.e. at the very next on ramp). It would be great if you could detect a way point being reached even if a previous one was missed.
  2. #32
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yeah.. that's a good idea.. but one of the codes I made had that in it.. I think I had to take that out because it was working right when for instance you had to go around something to come back closer to where you had to turn -- I may be able to do something about it though..
    Ride Runner RR's Myspace
  3. #33
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    How can I use the Base App?? I cannot find it anywhere??
  4. #34
    Low Bitrate dougmorgan99's Avatar
    Jul 2004
    Tulsa, OK
    That would be cool to have and "Auto-recalculate" feature, without the button! You think you can add to your evergrowing list? If it is a major task than I am willing to "donate" more development funds, just let me know! (I like the fact I can bribe you for added features, this is awesome! )
    Car: 2002 Dodge Intrepid SE
    Car PC: AMD XP 2500+, 1gig DDR, MSI KM4M mobo, GeForce 5200 128mb, Western Digital 250gig HDD, DVD, 802.11g, Rikaline USB Mouse GPS, WinXP SP1
    Screens: Lilliput 7" VGA Touchscreen and Lilliput 7" RCA LCDs
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by DjBac
    It's in the source packages under the base plugin folder.. I have done a few improvements already, so you may just want to wait for the final version.. but it doesn't prevent you from looking at the code and try to get the hang of it..
  6. #36
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by dougmorgan99
    I really have to do some testing to see if it is possible (that is reliably enough)..
  7. #37
    was Boston -> now Canada!
    Quote Originally Posted by guino
    Right now, you can add to favorites in the 'Add Location' screen.. (middle button across the bottom..) search for a location or use the nearby feature, select the location you want to add, hit "ADD" and type a name for the location... you can then use it in the route planning screen's "FAV" button ... you can delete what you want from that menu as well..
    You can add the current GPS position into the favorites by using the nearby function and adding the GPS position into the favorites as usual. Although it is a usefull thing to have direct access to it, I didn't have time to find a spot for it.
    The way to use show location is: set the country and city on the 'ADD location' screen (defaults are set in rrconfig). Then hit show location.. on the OSK all you put in is the STREET ADDRESS (nunmer+street name). and it will use the current Country/City to search and zoom onto that location. It will also put a push pin at the location in the map. To return to normal view, just hit the "POS MODE" button then "Show POS".
    I must be really dumb because I can't understand how this FAV function works. I was able to figure out the show location, I find it tedious to use but it works
    The FAV on the other hand is a different story. I followed your instructions and entered a location using the Route Planning Button > clicked add > searched for location > clicked ADD (middle at the bottom) > typed a name for the address (ie Mom and Dad). When I click the FAV button I see Mom and Dad in there.
    Here is the confusion....I go back to Route Planning click on the FAV and select Mom and Dad. I then click Route and Calculate and it takes me out West someplace to a street closely resembly the name Mom and Dad!!! For some reason when I type the name for the FAV it seems to use this as the address.
    What am I doing wrong?
    Thx,
    Chuck
  8. #38
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Interesting.. this is not supposed to happen.. you might be missing something in the way:
    STEP BY STEP:
    -Go into the route planner
    -Click FAV
    -Delete all of your favorites to be sure
    -Click Cancel
    -Click ADD on the route planner screen
    -Click on the street and enter the street name you wish to add to favorites
    -Hit SEARCH (NOT ADD -- yet)
    -From the results list, select the address you'd like to add to your favorites
    -Now hit ADD, and enter whatever name you want for the location
    -Hit ENTER on the OSK
    -Return to the route planner
    -Click FAV
    -Select the location you've added,
    -Click SELECT -- the name of the location should show on the list
    -Exit the planner and click - Route->Calculate
    If it doesn't show the route for the location you've added to the favorites, please send me your favorites.ini file so I can have a look at it.. I've been using it quite often lately with no problems..
    Let me know,
    Guino
  1. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 09:21 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 07:48 PM
  3. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 03:54 AM
