Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: RR 04-08-05 .. BETA Base Plugin ...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 04-08-05 .. BETA Base Plugin ...
    So here are the changes..
    -Added support to show aligned/scrolling formatted labels
    -Added support to designate buttons for playlist/folder list
    -Added SDK code to display controls on Video/DVD/Mappoint
    -Improved Mappoint's directions against duplicate road names
    -Fixed Close External Application bug
    -Fixed Bug adding files on root folders
    -Prepared a BETA Base skinnable plugin
    In case you wonder, combined label codes can now be separately formatted. So this kind of stuff is possible for labels: "MBM01||= / ||MBM02", "c2f|| ||0 V" this also allows for aligning combined labels: "=||MBM01", "center||c2f"
    The Basae Plugin is BETA. I intend to add support for pulling RR's indicators from SDK and add it to the code. If you feel the base plugin should have something you don't see, please let me know..
    Other than that, just a few fixes..
    Thanks for your great support,
    Guino.
    Ride Runner RR's Myspace
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, NOW it is ok... If you're seeing this message for the first time, and have downloaded 4-8, please redownload (before you start seeing weird behaviour in the audio browser).
    Aug 2004
    Grabbing now, thanks.
    I downloaded around when you fixed it - my first attempt was corrupt since I got a 64k file so I suspect I was just trying to download as you uploaded a fix. What would be the symptoms if I got a broken version? I just put my PC back in the car so I'll be checking it's ok in the morning before I head off to work.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you got it when it had the bug, It may prevent you from borowsing files at all.. that is, it will show you the folder list but won't let you go in them..
    Raw Wave
    Jun 2004
    On the beach
    Just looked at the base skinnable plugin stuff, good work Guino, just got to try to get my head around it all now, once I have expect loads of plugins for RR.
    To setup my own 'Skin' commands do these go through Exec? with the code as a case statement under there???
    Sorry to sound thick ... just double checking before I mess everything up this end!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah... everything you execute with skin buttons is channeled through EXEC (also in RR).. any commands you define there will be executed.. if the command is not in the list, the last case (else) will try and send it to RR so it may (perhaps) be executed there.. I still need to work a nice way for loading the plugins in RR..
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    thanks man I'll check it out tomorrow! is this what you were telling me about? sorry it's late and i don't quite understand...
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Raw Wave
    Jun 2004
    On the beach
    Can I add text fields using the Base App??
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    here it goes... another newbie question ..... what exactly does the base plugin let us do guino?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  1. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 10:21 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
