Results 1 to 7 of 7
Thread: Display labels from FreeDrive
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Lo, first of all sorry for being thick, but trying to suss this out. OK.. say I want to display my speed on any page in RR.. I assume I must first set a label up in the skin as follows - Lxx,xxx,...,"!FDSPEED","Loading..."
    Now, do I just use the same type of commands to send to RR ? Like COMSend "RoadRunner", !FDSPEED, "30"
    that type of thing ?
    Raw Wave
    Jun 2004
    On the beach
    Put the !FDSPEED in Quotes like "!FDSPEED" in the COMSend string
    Feb 2004
    Manchester
    ah cool thanks will give it a go
    CdR
    Feb 2004
    Manchester
    ok just add bit of code into freedrive so it 'should' now be able to send info out.
    I have hardcoded in this line, just to see if its working..
    COMSend "RoadRunner", "FDSPEED;30"
    now.. in my flash I have added a dynamic variable which is looking for a variable called FDSPEED, and I have also added the following line to the menu.skin (main menu) which should be all I need to do, but its aint working
    L11,000,000,000,000,000,000,000,14,"Arial Narrow:B","!FDSPEED","test"
    now I cant set !FDSPEED in flash as a variable, which maybe where its getting stuck.. any ideas ?
    Feb 2004
    Manchester
    ok got it working in a normal skin, but the ! but is giving problems when trying to call the variable in flash..
    CdR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Then we'll have to define something else for it to work in flash -- I wasn't sure this would work, but I have to specify some type of identifier in RR for custom labels or it will blank out any unknown tags.. You can either cut the flash and show the native "custom" label, or I can add something like "CUSTOMXXXXX" tags support where "CUSTOM" and "!" do the same thing..
    Ride Runner RR's Myspace
    Feb 2004
    Manchester
    yeah that would be good.. Got it working now with 10 out of the 12 different labels FD can send.. only 2 left :-)
    CdR
  1. Matrix Orbital GLK-12232 Display Software
    By dug1967 in forum General Hardware Discussion
    Last Post: 08-15-2006, 12:10 PM
  2. Dual Display Problem on M-II w/PowerDVD
    By DrDeriv in forum General Hardware Discussion
    Last Post: 04-11-2005, 05:16 PM
  3. Stupid Xenarc! It won't turn on when laptop is on or display correct!!
    By PDiddy in forum General Hardware Discussion
    Last Post: 01-17-2005, 07:53 PM
  4. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 09:14 PM
  5. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 10:43 PM
