Page 10 of 21 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 201
Thread: WANTED: Phoco BETA testers for RR...
  1. #91
    Mar 2005
    Germany
    well this could not work....change the "ACCEPT_CALL_PHOCO" to "DIAL_PHOCO"...
    thats it!!
  2. #92
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    OK, I fixed it (don't know exactly how) and all is working again. I started phoco manually and after that RR. Then I closed both and run RR again and phonecontrol opened like it's supposed to do.
    you can put the link back guino.
  3. #93
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by hematec
    thats it!!
    Ok hematec, now working correctly! Thanx
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  4. #94
    Mar 2005
    Germany
    @guino could it be, that the sourcefiles and the exe-file are not the same source???
    in the source the lines in the sub checkafter are missing, but the exe works fine...??
  5. #95
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    @guino & @hematec:
    Are you using the info that Zorro sent out about starting phoco?
    I'm having trouble... I restart my computer, load RR+Phoco, my phone isnt detected, I can go into phone it is as if there is no phone connected... if I receve a call RR/Phoco dont notify me...
    I can then quit RR/PhoCo and load PhoCo on its own, then it works, and I can go into RR and it will work.. it seems that when RR starts phoco it isnt forcing phoco to look for the phone and reset it and everything...
    Z sent me this saying to use this to start phoco hidden for max speed, I'm not sure if there is something here that you guys missed out, or if we are all at a loss...
    Code:
    Public Sub StartPhoCo(ByVal pi_sAppPathExe As String)
        Dim l_sPath As String
        Dim l_lHandle as long
        ' extract the path
        l_sAppPath = Left(pi_sAppPathExe, InStrRev(pi_sAppPathExe, "\"))
        ' start it
        l_lHandle = ShellExecute(0, "open", pi_sAppPathExe, "-remoteNoDesign", l_sAppPath, 0)
        If l_lHandle < 32 Then
          ' signal user that PhoCo can't be started (see ShellExecute for the "why")
        End If
    End Sub
    This starts PhoCo without using any Design file, so the startup is pretty much faster.
  6. #96
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @Hematec
    I may have not updated the package correctly.. I'll review the code to add that "ACCEPT_CALL_PHOCO" (as well as "DIAL_PHOCO") and repost the beta4, with a fresh source package..
    @RoyN
    cool.. I'll add that...
    Ride Runner RR's Myspace
  7. #97
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, Just updated the Beta4 Update:
    http://rmc.pimpedwheels.com/PhocoBeta4.zip
    also updated the sources:
    http://rmc.pimpedwheels.com/RoadRunnerSource-Phoco.zip
    This should fix the Answer call bug ("ACCEPT_CALL_PHOCO" command is now added -- but "DIAL_PHOCO" can also answer calls). Also added the -remoteNoDesign to load phoco faster..
    Is there anybody still having Phonebook issues ?? and if so, did you try that test app Hematec made to show the phonebooks available from your phone ?
    Thanks for the help with this guys...
    Guino.
  8. #98
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    I downloaded the newest files and I just configured the new WIDCOMM drivers so that I can accept calls and hear them over my speakers, as well as talk from a mic. whenever I recieve an incoming call RR will lower it's volume, but I don't get a screen that gives me an option to answer/ignore/etc. I was able to see this screen when I was using the windows drivers, but not with the WIDCOMM drivers. I beleive the problem also arose when I got the newest version of the program. phoco would open, but not be visible, and it is now. any ideas?
  9. #99
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try to start Phoco BEFORE RR runs to see what happens.. also, check if you get a call notification in Phoco alone.. I'm waiting on my phone to be able to do any tests myself...
  10. #100
    Mar 2005
    Germany
    @ATXAccord
    is the volume lowering or muting when you get a call???
    could you dial out of RR? Is there a skin file named call_in.skin??
  1. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  2. Beta testers: AiPC2
    By Seraph in forum Software & Software Development
    Last Post: 01-22-2004, 01:58 PM
  3. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
  4. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    Last Post: 05-07-2002, 12:58 PM
