Page 12 of 21 FirstFirst ... 23456789101112131415161718192021 LastLast
Results 111 to 120 of 201
Thread: WANTED: Phoco BETA testers for RR...
  1. #111
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    With all the versions I tested, the music stops playing when a call comes in BEOFRE I EVEN ANSWER... so I get no music until I ignore the call....
    Also, call comes in, volume goes to 100% for a split second then mutes.... I speak, then hangup, music comes back at 100% then goes to the normal level...
    Is this phoco or RR? What audio line should I be using in RRConfig? What is the best to use, I never figured out the difference
  2. #112
    São Paulo, Brazil
    Mr. Fabio, that is when u start phoco manually, no? when RR starts phoco in remote mode, the skin will never show (phoco skin) as it wont even be loaded
  3. #113
    Nov 2004
    St Louis
    Quote Originally Posted by hematec
    i will change this thing with the calls...
    editing the phone and sim phonebooks is still not supported by the phoco sdk...
    when its available i'll change this of course...
    Can you change the internal address book to match the format used by Zorro?
    I have two Phone Control Phone books I use with my PCMCIA CDMA phone card. And its would be a royal pain to convert it over to the RR "addressbook" file manually. Also if there are any other PhoneControl users with internal phonebooks this would help them too by letting them just point RR to their phonebook and it works.
    Just trying to maintain compatibility.
  4. #114
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    No RoyN I load only RR, and after some seconds , when Phoco is too loaded, RR starts. Until the previous beta release I didn't have these problems
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  5. #115
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    everything works great for me in RR, just trying to figure out why my audio gateway connection won't let me hear the other person through my speakers with my t610, maybe my s710a will be better...any ideas?
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  6. #116
    São Paulo, Brazil
    mine works with the t610... go to the phoco forum and search, i explained my procedure
  7. #117
    Nov 2004
    St Louis
    Quote Originally Posted by GizmoQ
    A little clarification. The following is my address book:
    And this is part of my Phone Control phone book:
    The differences are minor, but significant. The names of the categories are somewhat different, but more importantly RR address book uses on entry per name, whereas, PhoCo phone book uses one entry per number and as long as the names exactly match, it pulls all entries for that name together when its loaded. I'm assuming Zorro did this for compatibility with the various skin formats used with his program. Pages 19-21 of the Phone control docs talks about these phone book locations and specifically addresses static phone books thus:
    I realize the RR PhoCo is still beta and I don't know what criteria Zorro uses when identifying front-end with internal PhoCo support, but two of the other frontends I've tried that support PhoCo also support my static phonebook without changing anything just pointint it to the file.
    Great work so far! I really love whats being done with Road Runner.
  8. #118
    Mar 2005
    Germany
    so would you like to have one entry for every number in your phonebook in your list off the internal phonebook off RR???
    if you load phoco you'll still have one name entry with several numbers...
    the phonebook of phoco is used in RR in the phone phonebook until you press "reload"...
    or to you mean that there may be problems when you have double entries per a name??? f.e. you have 2 entries maybe name: "xyz" and once with numberwork "123" and a second with numberwork "678" ????
  9. #119
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    @GizmoQ:
    I don't understand the whole idea behind "converting" addressbook files into RR's format.. RR should be able to load the phonebooks from the phone and no conversion would be necessary then..
    From what I see the Phonebook Hematec implemented is superior in details than the one from Phoco.. If you have any issue with loading the phonebook from the phone into RR, then we need to fix that ..
    Ride Runner RR's Myspace
  10. #120
    São Paulo, Brazil
    Guino, some phones dont support importing the pb, and some people want an option of having an extra pb (like from outlook) and that is what he is reffering to i think...
    He wants to use the phonebook that he currently has from phoco in RR's phone
  1. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  2. Beta testers: AiPC2
    By Seraph in forum Software & Software Development
    Last Post: 01-22-2004, 01:58 PM
  3. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
  4. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    Last Post: 05-07-2002, 12:58 PM
