Page 5 of 21 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 201
Thread: WANTED: Phoco BETA testers for RR...
  1. #41
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    hmm, weird, phonecontrol launches on my pc because I see it's window on the taskbar. I can't open it but that's because RR is controlling it. Try do dial to any number to see if that works (that's the only thing I can do)
  2. #42
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    nope doesn't work either :?
    i have the trial version does that matter?
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  3. #43
    Mar 2005
    Germany
    hi,
    my mistake. please comment out the line in frmCOM
    which is:
    'Call ParseXML(left(m_sRecvBuffer_PHOCO, Len(m_sRecvBuffer_PHOCO) - 1))
    this sends the xml messages to RR
    also please change:
    winsPhoCo.GetData l_sTmp
    to:
    call winsPhoCo.GetData l_sTmp
    also i updated the modPhoco.bas and changed the startup and closing of phoco.
    its no difference if phoco is running or not, but it will be closed when you close roadrunner. you can now also tell RR if you wish to save your call list and how many entries you want maximal at your list of every type (default 25).
    please check before you use phoco with RR that it works correct when you start it manualy. in the config-file of phoco the remote-port has to be set to 17015 (is the default value)
    Attached Files Attached Files
  4. #44
    Mar 2005
    Germany
    i forgot that you now had to write the complete path to the phoco.exe in the phoco.ini not only the path!!!!!
    but this only if you use the new version of the modPhoco.bas
  5. #45
    Feb 2005
    The Yay Area (SF)
    did those changes, still doesn't load for me.
    phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
  6. #46
    Amsterdam
    shouldn't that be program files instead of programme ?
    I think hematec is using german windows, hehe.
    phonecontrol is launched here again (only path without the exe in ini file), but now nothing works. I have done all the changes.
  7. #47
    Feb 2005
    The Yay Area (SF)
    yeah well mine is phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
    and even when i have phoco open myself the two don't seem to interact at all...
  8. #48
    Amsterdam
    It's getting late (03:06 AM) and my eyes are closing so I'm going to sleep. I will continue testing tomorrow.
  9. #49
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The changes made by hematec will only work after re-compiling the sources.. I'm updating this right now.. and I'll re-post it in a little bit..
    Ride Runner RR's Myspace
  10. #50
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    do the changes effect any of the possible problems i mentioned?
    phonebook, incoming calls, etc.?
  1. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  2. Beta testers: AiPC2
    By Seraph in forum Software & Software Development
    Last Post: 01-22-2004, 01:58 PM
  3. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
  4. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    Last Post: 05-07-2002, 12:58 PM
