Page 6 of 21 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 201
Thread: WANTED: Phoco BETA testers for RR...
  1. #51
    Mar 2005
    Germany
    that are the sourcefiles....you have to add them to the vb-project!!! to get an .exe file you have to compile them.
    what version of phoco do you use???
    to check if the winsock connection works, start phoco manually, then open hyperterminal, name a connection, set type/used modem to tcp and type for the host 127.0.0.1 and port 17015. if you connect, you should see the first messages from phoco...
  2. #52
    Mar 2005
    Germany
    yes they do! because RR got no data from phoco, Phoco could not interact with RR and so RR got not phonebookentries, message about incoming calls, and so on...
  3. #53
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, I've updated the main download file as well as re-compiled it for those without VB:
    http://rmc.pimpedwheels.com/PhocoBeta4.zip (just unzip over your current files AND ADJUST YOUR SETTINGS IN PHOCO.INI)
    This makes a lot of sense since everyone coundn't get any incomming information from Phoco.. this version should provide for it to work.. Thanks Hematec.
    Ride Runner RR's Myspace
  4. #54
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    im confused i'll just wait a while to try again. i have phoco 1.4 trial version, i'm not sure what hyperterminal is but phoco works fine by itself, just doesn't interact with RR-this is with the update you just posted...
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  5. #55
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    get the latest version contaygious.... post #53... read #52 for explanation...
    no need to wait a while it is working now apparently
  6. #56
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yeah, you just need to unzip that Beta2 update over your current setup, make sure the settings in Phoco.ini are set (the package has new settings) and try again..
  7. #57
    Feb 2005
    The Yay Area (SF)
    ha still confused. won't open phoco, does anyone else have it working with the trial? do i need full version?
  8. #58
    Mar 2005
    Germany
    with the trial you'll get a problem at all...because the trialversion show a info screen on startup...on solution should be to start phoco before running RR...
  9. #59
    São Paulo, Brazil
    also edit the phoco.ini to contain the PhoneCtl.Exe filename in the end... the zip file's phoco.ini doesnt have the exe name!
  10. #60
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    Master !
    It's working here and I just lost the need to sleep, hehe. I can call and receive calls.
    One minor thing: simcard contact and internal contacts work, but I can't read the internal phonebook from the phone.
  1. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  2. Beta testers: AiPC2
    By Seraph in forum Software & Software Development
    Last Post: 01-22-2004, 01:58 PM
  3. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
  4. Wanted: beta testerss for X-MP3Pad (formerly MP944)
    Last Post: 05-07-2002, 12:58 PM
