Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: horm stuff
    Feb 2005
    horm stuff
    Do you have roadroader re-loading the resume.ini file after hibernation (even rr was used to hibernate) with the hibernatereload=true ? Because the playlist and such is being saved/reloaded but rr always plays the same song # on the playlist.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The order of things RR is doing on resume is:
    WinAMP ClearPlaylist
    WinAMP Open Playlist (Winamp.m3u)
    RR Reload of playlist
    RR Reload Resume.INI
    RR Reopen Open COM Ports
    RR Restore Shuffle&Repeat Mode
    I'd suggest save your HORM save point with winamp STOPPED. This should allow RR to resume propperly when using HORM, because the Reload Resume.INI function does absolutely nothing if winamp is currently playing (and that's where the song number/position is set for resume playing)..
    Ride Runner RR's Myspace
    Raw Wave
    Jun 2004
    On the beach
    You also need to ensure your Road Runner installation is on a writable partition otherwise it will always resume playing the same track.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    is there any special reason that road runner always comes back from resume without any music playing? this happens when I am on the audio player screen... hibernate, resume from hibernate, msuic is stopped.. music status label says "STOP"...click PLAY, no music, status goes to "PAUSE", click play again, music starts playing normally...
    If i click on the menu as soonas I return from hib(without musc) it starts playing music... what gives?!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    using the always resume option RR tries to resume when loading/changing screens.. when resuming from Hibernate, RR also tries to resume music. I think you're having an isoleted problem there.. resume on hibernate has always worked for me, independent of RR version.. I have to improve a few things but I'll try to do it later today for release..
    São Paulo, Brazil
    Sorry I didnt realize this was HORM as in EWF... dur... how elese could it be...
    but just FYI, my setup is regular hibernate/resume, but still it doesnt resume playing until I change modules...
    If I dont put "resume music when coming back from hibernate" or whatever the correct name is, in rrconfig, then it works... What are the advantages of using that option?
    Feb 2005
    Ah... so Winamp shouldn't be playing a song when you set your hibernation point? Or winamp shouldn't be open at all? This is probably the problem.
    And yes, RR is on a seperate writable partition apart from the OS.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    winamp shoudn't be playing music (but probably open) -- just hit stop before making your save point.
    I'm adding a prevention against this for next version..
    Feb 2005
    I still cannot get this to work for the life of me. I have updated to the newest version of RR and I've set new save points with Winamp stopped and it seems that resume.ini isn't being reloaded after hibernation. I know for a fact that resume.ini is being saved with new information before shutting down but when I come out of hibernation, the playlist is corrected properly and such, but the resume.ini info isn't being reloaded. Any other ideas?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Tell me exactly what happens exactly by answering those questions one by one:
    -Is winamp reloading the correctplaylist last used?
    -Is the last song playing being re-selected in the list?
    -What exactly are the contents of your resume.ini imediately after resuming from hib. ?
    Depending on what is happening it will be a different issue to deal with.. I am also looking into a current issue where winamp doesn't seem to be found imediately after resuming from hibernation -- It's either that or winamp is resuming music on its own .. the problem you're having could be related to it..
  1. WTT Bass/Guitar Stuff for Carputer Stuff
    By screwmesa in forum Classified Archive
    Last Post: 04-15-2005, 11:31 AM
  2. FS: stereo stuff and computer stuff
    By RedGTiVR6 in forum Classified Archive
    Last Post: 01-25-2005, 05:45 PM
  3. Nearly free stuff!
    By lburton in forum Classified Archive
    Last Post: 10-24-2003, 09:52 PM
  4. some stuff for sale..inverter, fm modulator
    By pogue1000 in forum Classified Archive
    Last Post: 08-19-2002, 06:49 PM
  5. Replies: 16
    Last Post: 06-25-2002, 01:16 PM
