Results 1 to 10 of 20
Thread: AVS- Add a button to change
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    AVS- Add a toggle button
    I was wondering if its possible to add a button on a skin to toggle the AVS plugins, on MediaCar it cycled every 5 secs or so. I like the curent way RR works by keeping one until changed, but its a ***** on touchscreen to right click and pick another vis.
    ThX, ill look more into it in the meantime
    throw a moon
    heuvos vin chevos
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is something you can set up on the AVS plugin itself.. I have mine changing every 3 seconds ...
    Ride Runner RR's Myspace
    Aug 2004
    tx, USA
    ill look into creating a shortcut or soemthing, i like staying on one vis but would like to change them in an easier way when needed
    throw a moon
    heuvos vin chevos
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm not sure if AVS supports hotkeys, if so, I can try adding something for it..
    Aug 2004
    tx, USA
    yea it supports hotkeys but only for specific visualizations. for example F1 for visualization#1 F2 for vis#2, you cant use a single hotkey to cycle though. This is at least what i have found out thus far. Maybe creating a button that would cycle F1-F12 and narrow your visus to 12. I could live with that to be able to cycle them more easily. Ill keep looking.
    throw a moon
    heuvos vin chevos
    Aug 2004
    tx, USA
    i tried setting it up to the numbers 1-9 but the OSK steals focus and therfore will not change the VIS. Any other options? Maybe a button that would call a small on screen board to pop up on the bottom of the screen with numbers 1-10 or whatever, just dont know how to keep focus on the VIS itself while doing this.
    throw a moon
    heuvos vin chevos
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can simply create a .skin file and load it with the menu command, then on this "menu" you should have codes like:
    "EXIT||SENDKEY;<KEY>" for each button... this should produce the effect you want.
    Aug 2004
    tx, USA
    Do you have any suggestions for keeping focus on the VIS screen so the buttons will work the way i want. I remember reading a post on some other thread about routis i believe where someone had a problem keeping somethign in focus for a certain key to work, i think it was zoom, for a routis skin. I cannot find the thread now
    throw a moon
    heuvos vin chevos
    Aug 2004
    tx, USA
    only reason its not working now is tha fact i cannot keep focus on the damn VIS, even if i click it then push ONE on the OSK
    throw a moon
    heuvos vin chevos
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ummm.. I'll add a command "GETFOCUS" so that you can add it behind any command you wish to execute and reaquire focus afterwards.. like "SENDKEYS;<WHATEVER>||GETFOCUS"
    Then it whould allow you to keep focus when needed. This can also work for other situations..
  1. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 09:15 PM
  2. ITPS reprogramming ?
    By naruto in forum Power Supplies
    Last Post: 11-26-2004, 01:19 PM
  3. [POLL] AVS in neocar media center
    By netsuo in forum NeoCar Media Center
    Last Post: 11-18-2004, 08:04 PM
  4. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 02:36 AM
  5. internet button on my pc
    By babas151 in forum General Hardware Discussion
    Last Post: 05-31-2002, 02:41 PM
