Results 11 to 20 of 25
Thread: Phone control in Road Runner
  1. #11
    FLAC mauri's Avatar
    Jan 2004
    @ Guino or another boys
    Please, write one "full tutorial" for settings, use etc. to Phoco embedded RR.
    I am sure that this would help many in the forum to correctly use Phoco
    Thanks !
    Mauri
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I can hardly find time to code right now.. imagine to write tutorials.. anyway, the user "drait" started doing a tutorial awhile ago, but I think he ran out of time as well.. it is a whole lot of stuff to keep up with.
    Ride Runner RR's Myspace
  3. #13
    Apr 2005
    lancashire
    Quote Originally Posted by guino
    May be you should double check your Phoco settings and make sure that it's setup to allow connections (servermode) on the default port... otherwise RR may be stuck trying to connect to it...
    I would try this, but I would not know how. have tried searching this and the phoco forum. could anybody point me in the direction of how to do this.
  4. #14
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    is the bluetooth dongle that guino bought the 9.99 plus 9.99 shipping? adaptor and shipping are the same price. does it work good?
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    It's a crappy brand but works allright.. it's definitely not as high-wuality as the $50 ones out there.. The only issue I have so far is that in my carputer, if I boot up the computer with the device plugged in, it sometimes freezes the bios when "Initializing USB Controller" -- ****es me off since the bios has no business messing with my USB stuff unless I tell it to initialize legacy devices (which I don't).
  6. #16
    Apr 2005
    lancashire
    There is definetly something wrong with RR, Phoco and my computer and I think it's RR. My reason for thinking this is because everthing, including phoco works ok with centrafuse.
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Ok, did you try checking/unchecking the -remoteNoDesign option.. do you have the latest Phoco version ? Perhaps if you post your RR.INI it could be of help..
  8. #18
    Apr 2005
    lancashire
    yes, I have tried checking/unchecking the -remotenodesign option.
    yes I have the latest phoco and its registered.
    my RR.INI is standard and works until I turn on the phone in the settings dialog.
    If its of any help, my phone, a SE P900 is a symbian smartphone.
    the problem must be in RR,because, as I said, everything works ok with centrafuse, the only different software is the frontend.
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Have you tried the version 5-6 ? I did change a few things with starting Phoco... in any case, you still haven't posted your RR.INI settings..
  10. #20
    Apr 2005
    lancashire
    I have the latest version according to RR updater
    as I said I have only used RRconfig to change RR.ini but here is my RR.ini
    Or at least it would be if I could paste it here
    anybody care to tell me how I cut and paste into a forum message?
  1. Road Runner Skin web Folder
    By maxzor in forum RR Skins
    Last Post: 08-09-2005, 08:24 PM
  2. Can phone control...
    By BiohazrD in forum PhoneControl
    Last Post: 03-24-2005, 12:19 PM
  3. Phone control and bluetooth dongle
    By Paddymcc in forum Software & Software Development
    Last Post: 01-10-2005, 08:37 PM
  4. auto launch phone control
    By robr in forum MediaCar
    Last Post: 05-17-2004, 11:54 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 12:30 AM
