Results 1 to 10 of 10
Thread: Base Plugin Questions
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Will there be a FAQ for the Base Plugin?
    How can we use it in order to skin our own applications?
    I have made an app for HVAC and some more stuff... It can communicate with RR and MM fine!! But my only problem right now is skinning!
    Raw Wave
    Jun 2004
    On the beach
    Use the Base Skinnable App to skin your own programs using the same skin format as RR. Open the Visual Basic App in Visual Basic - all the code is commented so no FAQ required really.
    Jun 2004
    GREECE/Athens
    I've already whecked the code.. The problem is that I am not too keen in VB!! I had to learn some in order to write my app!!
    Any more help would be really appreciated, although I will check it more carefully!!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There really isn't much you need to do with the base plugin:
    -Design your skin
    -Define your buttons/labels in a .skin file
    -Open the Base PLugin
    -Name your project in frmCOM (as the Comments tells you to)
    -Add any button codes from your skin/software in the select statement of the EXEC function
    -Add any label codes from your skin/software in the select statement of the LabelInfo function
    That's about it for a simple application... And to be clear, the plugin you make can be used in RR or stand alone..
    Ride Runner RR's Myspace
    Jun 2004
    GREECE/Athens
    I think I am getting somewhere now!
    But I am having a problem to add button codes from my soft!! How should I do that!
    Jun 2004
    GREECE/Athens
    Some more help please??
    Raw Wave
    Jun 2004
    On the beach
    What help?
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by DjBac
    Some help on this?
    How should I define my buttons codes?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Man, sorry, but did you even look ?
    Please don't make any software available, without looking over at least the modules of the software..
    This is what you find in the 'Exec' function:
    '* Commands NOT used for navigation *
    Case "mycommand1"
    'Add here any custom commands..
    Case "mycommand2"
    Label codes are defined in the 'labelinfo' function somewhat like the buttons..
    Jun 2004
    GREECE/Athens
    I tried to have indicators (both RR and for my app)...
    I've copied pasted some code from RR source code to the base plugin.. (GetIndicator function).... But NO luck!!
    Should there be another way?
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. Help with winXP/hibernate/LCD plugin
    By dave123456 in forum Software & Software Development
    Last Post: 10-17-2002, 09:17 PM
  3. winamp audio level plugin
    By darkwingduck in forum Software & Software Development
    Last Post: 07-27-2002, 09:37 AM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
