Results 1 to 10 of 20
Thread: RR 04-19-05.. Improved Phoco..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 04-19-05.. Improved Phoco..
    In This version:
    -Added Keyboard Support for PhoneBook/CallLists
    -Added "GETFOCUS" command for skins/remote
    -Added Peveition against double clicks on empty areas
    -Improved Phoco support to close it propperly and faster
    -Improved Phoco support to auto reload SIM card (if any)
    -Improved Phoco support to Load PhoneCTL.PB.XML when internal addressbook is not yet present
    -Improved Phoco's Interfacing to prevent missing messages
    -Fixed Loading Call Lists From Phoco -- This does takes a few seconds
    -Fixed Phone's Signal Strength display (wrong scale)
    -Fixed fast highlighting buttons "bug" of badly defined skins
    -Fixed Flash and Clipping Window/Flash Regions to resize correctly
    -Fixed Girder/Video Player Issues from version 4-15
    Notes:
    -The Flash Objects in the skins may need to be resized according to your logo (The wrong aspect ratio was being used -- now you should make sure to set the flash object using a propportional aspect ration you want to see)
    -This version may NOT close phoco at all times, this is because RR was always ending up killing Phoco's task and leaving icons on the taskbar. (I'll look into it a little more)
    -I hope to have fixed most issues with Phoco now
    -If you want RR to always load your call list from the phone, simple leave the Callsfile option in RRConfig BLANK.
    Let me know,
    Guino.
    Ride Runner RR's Myspace
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    first to see the update! yohoo!
    gonna fetch now, and comment later.... just post whoring for now...
    Have you checked any of the problems of the phone going away from RR and RR not changing the phone status and the user thinking the phone was still around with the last battery/signal status as before?
    and also when the phone comes in range the fact that RR wasnt re-finding it....
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    Thank you guino, it seems to work well, I will do more research tomorrow, I just wish I could get the red alpine skin updated for PhoCo I will donate once I pay off a slight debt I have.
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Just downloaded - Thanx
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    sweet job guino could you please explain the
    "-Added "GETFOCUS" command for skins/remote"
    thanks!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    Nov 2004
    St Louis
    PhoneCtl.PB.xml
    YES! YES! YES! Outstanding support!!!!!!!!!! My PhonCo phonebook works great!!!!
    THANK YOU!
    THANK YOU!
    THANK YOU!
    THANK YOU!
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by contaygious
    thanks!
    This is so that for instance if you have a command that when executed makes RR loose focus (i.e. after use "SENDKEY") and you'd like it to return to RR for whatever reason (say to be able to use the keyboard), you can simply append this to your command like: "SENDKEY;A||GETFOCUS" would send the letter A to whatever application is active and return the focus to RR afterwards. Use of this may vary -- but this is a way, for instance, of keeping focus in RR after starting a VIS plugin...
    Mar 2004
    California
    PhoCo
    Now if I can only find out how to configure PhoneControl properly, considering I paid for it.
    So far, no official support for my Treo650, or T-Mobile h6315. Still looking into using my older Sony Ericsson P800. Looks like there's SOME support for it, but I need to track down a client app for the phone itself.
    Anyone use a P800 with PhoCo? Why is PhoCo so disgustingly over-complicated?
    Kevin
    Audi A4 Carputer, 80% setup.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by kevlar
    Well, honestly, I think as long as you install the WIDCOMM thing exactly as they describe it, it should work.. I actually tried it out with the drivers from the device I got and with MS drivers and even with WIDCOMM I had issues, but really phoco works nice when you have the MACHINE issues figured out.
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i don't know if this is necessarily what you would call a bug, but i am still having trouble with the sendkey buttons in the external gps screen with iguidance. in most instances the senkeys work perfectly. the one instance where it does not work is if i run iguidance embedded in roadrunner, then close rr leaving iguidance running in the background, the next time i open rr and go to the gps screen, if i click on any of the sendkey buttons, they do not work. i have to first click in the iguidance window, and only after that will the sendkeys work.
    i've also done some work on the skin i started... improved the osk and made other minor modifications. www.inorkuo.dynu.com/rr_clean_skin/800x480/
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  1. WANTED: Phoco BETA testers for RR...
    By guino in forum Road Runner
    Last Post: 12-05-2005, 10:05 AM
  2. RR 04-15-05.. Hope you did your taxes.. ;)
    Last Post: 04-18-2005, 12:15 PM
  3. XP Pro nlited not working with RR and Phoco
    By mick0uziel in forum WinNT Based
    Last Post: 03-13-2005, 01:18 PM
