You can try this: make your button show a menu using "MENU;<SKINFILE>". That menu can show as a popup or as a full screen window over the current one (so it can look like the same screen). Then on the menu screen you place your flash animation. The flash animation would check for a variable called "RRSCR" that tells you which screen RR is showing, then if it is your <SKINFILE>, you should start your movie, then at the end of it, issue a fscommand from flash to execute "MAPPOINT" or "DESTINATOR" etc ... you can even issue a "RUNGPS" command that would be a customized parameter specified in ExecTBL.INI so users could define what to execute at the end of the animation.Originally Posted by tolisn
The above requires no modifications in RR, but does require knowledge of Flash. I don't have any (decent) way of checking the status of a flash movie from RR so the above is pretty much the only way out.. if you try it and it doesn't work, I can definitely work out with you on the issues.
LinkBack URL
About LinkBacks
