How about some info on your hardware....
Project done in: [####################] - 85%
- Custom center console
- Custom trunk
Se my project here
- Custom trunk
Se my project here
First time i hear this problem... How many Mp3 do you have? Have you tryed to cancel the current playlist and re-create a new one?![]()
Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
RoadRunner - PC Navigator 7.1 - FreeFone
I got 3 mp3s..Originally Posted by Mr.Fabio
and tell my how to reset playlist, when everything under MUSIC is so slow that I get sick aout that... I even look after P4 solution becouse Epis is tarting to make very mad.
I just installed RR 4-18-05 after uninstolling old version whitch worked fine...
help needed, thanx...
Ow BTW! I will use RR, even If I have to buy Insight P4![]()
- Custom trunk
Se my project here
Take a look in the RR dir and search/delete this file : winamp.m3u then restart RR. I'm using a DB with over 2500 mp3 without problems on a epia M10000...
Fabio
Travla C134
winamp.m3u no such file there.
I think I will reinstall whole system and see what happends then...
- Custom trunk
Se my project here
No, is not necessary.. Look in the RRConfig and search the path of your Winamp dir. You will find there the file winamp.m3u
Make me know![]()
Fabio
Travla C134
I was wondering if you have problems with phoco.... If you want you can try to leave blank the path of Phoco.......
Fabio
Travla C134
it is blank... Phoco is uninstolled. I am truying to get to work one thing on the time..
When I get music part of RR to work I will try Phoco...
I think the system reinstall is the only way to fix the problem...![]()
- Custom trunk
Se my project here
