You should try uninstalling the TV plugin, deleting the plugin.ini file int he plugins folder of winamp, then install the new TV plugin.. I've seen many issues with the plugin trying to remember older settings (crashing etc). The latest plugin has directshow audio support which should work using the USB cable only. For Radio, I am unsure if you can specify a audio line to unmute or record from using the line in plugin.
LinkBack URL
About LinkBacks
