Results 1 to 4 of 4
Thread: Temp monitors
    Constant Bitrate nibix's Avatar
    May 2004
    Temp monitors
    I noticed that the Interface has temperature monitors. Where can I get the hardware to add the temp monitors? I want to put one in my PC and one inside the car. Sorry if this has been answered before, but I might have been using the wrong words while searching.
    2004 Freelander HSE | Lilliput 7" VGA Touchscreen| Via M10000 | 256 MB | 120 GB | DVD player | TN-200 | Opus 150watt |Windows XP Pro | Media Car | Routis & Destinator
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Well your motherboard has built in sensors for CPU and case and fan speed....
    Go to Guinos home site and use the link to down load MBM5. This program can be used to get this sensor info and pass it to RR using the MBM command from within RR skins. THe MBM5 program must be running all the time in order for RR to get this info.
    As for the car sensor, "Mauri" has made available his sensor circuit which you can DIY. Search for him on this forum and you will find the answer. Also you can buy a device called Phidgets that is also compatible with RR.
    The road is long but we are getting there.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The sensor that is supported as a "standard" in RR is the one listed on my website.. Kit #145 from Kitsrus.com .. there are distributors in many locations in the world.. some will even sell it assembled.
    Ride Runner RR's Myspace
    Nov 2004
    How do i change the skins to use motherboard temp instead?
    Best Regards
    T-Bear
  1. What size / resolution headrest monitors?
    By jedi7001 in forum General Hardware Discussion
    Last Post: 03-13-2005, 11:42 AM
  2. Temp sensors in the case
    By edrex in forum Road Runner
    Last Post: 02-15-2005, 09:58 PM
  3. Temp displayed constantly?
    By Skipjacks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-30-2004, 04:08 PM
  4. quesiton about monitors..
    By tsparks in forum LCD/Display
    Last Post: 07-10-2004, 05:41 AM
  5. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
